Something truly bizarre happened this week. I brought car into dealer to have cracked muffler paint on stock mufflers fixed. When I got the car back, the rear suspension felt softer and the steering less precise (more understeer). They swear rear thresway bar was properly reconnected after repair. Any ideas ?
Click:This one is easy.
Clack: Yes it is. they painted right over the muffler bearings.
Click: In addition, they used latex pain. Not oil paint.
Clack: Now time for the puzzler.............
Sometimes they have to loosen the suspension/tranny bolts to get the passenger side exhaust off the car. Make sure they tightened them correctly if they indeed did loosen them.
I thought they got those damn muffler bearing problems fixed in September. I thought it only effected the first couple of hundred cars!
For your info: He also posted the question in the C5 section. Don't you know when somebody is goofing on you?
Not kidding. Have you never taken your car into a dealer for one thing---and have it come back with a totally different problem ? If that has never happened to you, you should consider yourself lucky.
C'mon now!!!!!!!!!!!!! Muffler paint???
You'll notice he hasn't responded.
Only shop my car has seen is the alignment shop, and I was hound ******* him the whole way. I once took my truck to get the oil changed, and they screwed that up...
