C6 Z06 specs....
Old Jan 27, 2005 | 01:24 PM
Kid's Avatar
Kid
Default C6 Z06 specs....
I got these from another forum. A lot of you might have already seen this.
Very impressive!
Spec's:
0-60 in 3.8 sec.
Top Speed 200 MPH
2,900 #'s
5.7 #'s/HP
Chassis & Suspension development by Pratt & Miller,
Aluminum Hydroformed frame produced by DANA
- 345/30x19 Rears
- 6 piston Front, 4 piston Rear Brake Calipers
- Cross Drilled (cast and camfered) Rotors (possibly Brembo)
Engine Development by KaTech
To be hand built by new HP Engine Plant
LS7 427ci/ 7.0L. 500HP/500 Ft Lbs (512 HP derated to 500HP)
- 2 OHV (3 OHV not necessary for target HP)
- Raced based CNC ported Aluminum Head with 70cc chambers
- 11.0:1 CR
- 46 mm (1.81") Titanium Intake valve
- 41 mm (1.61") Na filled Exhaust Valve
- 104.8 mm Bore (4.125") , 101.6 mm Stroke (4.0") Aluminum block
- Forgrd Crank
- Forged 6 bolt main Bearing Caps
- Titanium Rods
- Cast Aluminum Flat Top Pistons
- 0.591" Lift Cam (15 mm)
- Dry Sump
- 90 mm Throttle Body on Composite manifold
- Ram Air
Old Jan 27, 2005 | 01:35 PM
Z064life's Avatar
Z064life
St. Jude Donor '06
Very impressive!
Spec's:
0-60 in 3.8 sec.
Top Speed 200 MPH
2,900 #'s
5.7 #'s/HP
- 345/30x19 Rears
- 11.0:1 CR
- Forgrd Crank
- Titanium Rods
- Dry Sump
- Ram Air
These are old specs...especially the 2900# weight. It is ~3130.
Get with the picture...it was released at autoshows Jan 10th, and these specs were available before that
I'm not even going to look for all the threads that have this exact same info in them, and those that have the REAL info in them...I'm just going to give you a nice little
