reset oil change register
Old Jan 29, 2005 | 11:14 PM
luscombe's Avatar
luscombe
Default reset oil change register
when one changes ones own oil, do you reset some counter? or does the "brain" sense new oil and new condition?
if a manual reset is required, how does one do it?
thanks
doug
Old Jan 29, 2005 | 11:39 PM
Vette_DD's Avatar
Vette_DD
With the engine running, use the "gages" display button to bring up the % oil life left display on the DIC. Press and hold the RESET button until it reverts to 100%. That's all it takes.
Old Jan 30, 2005 | 10:05 AM
50-50's Avatar
50-50
But in case ya forget... it's in the owner's manual
Old Jan 30, 2005 | 03:26 PM
WWK888's Avatar
WWK888
Does the "pushing the accelerator 3 times with key on, motor off " method still work in the C6 as it did in the C5?
Old Jan 30, 2005 | 03:42 PM
shopdog's Avatar
shopdog
No key.
Old Jan 30, 2005 | 03:54 PM
WWK888's Avatar
WWK888
Ahhhhh...forgot about that.
Old Jan 31, 2005 | 04:00 PM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Old Jan 31, 2005 | 06:23 PM
LS WON's Avatar
LS WON
Default Just go to your DIC and bring up the Oil Remaining then hit the reset button
Then it will go back to 100%
To reset oil change register
