interior lights not going off
Old Jan 30, 2005 | 08:35 PM
randall reeves's Avatar
randall reeves
Cruising
Default interior lights not going off
All of a sudden my interior lights will not go off after starting and driving the car.Last night they went off after turning off and after 20 min.
Old Jan 30, 2005 | 09:25 PM
MattW_VA's Avatar
MattW_VA
St. Jude Donor '07
Check the little switch on the dash that will be in the neighborhood of your left knee-easy to hit on entry/exit
Old Jan 31, 2005 | 06:20 PM
LS WON's Avatar
LS WON
Default Isn't that little switch by your left knee suppose to dim your speedo and tach?
basically illuminate the whole dash from light to bright? It will shut off the lights you might have to push it and turn it.
Old Jan 31, 2005 | 07:59 PM
Vette_DD's Avatar
Vette_DD
No, pushing it and turning it accomplish 2 different things. Pushing it in and releasing it just turn on or turn off the interior lights. Turning it (only) dims or brightens the dash lights.
Old Feb 1, 2005 | 12:33 AM
LS WON's Avatar
LS WON
Default I tried it again and this switch only controls the interior lights & map lights.
Isn't there a way to control how dim or bright you want your dashboard gauges, speedometer and tach? I also read this in the manual but it is not working.
Old Feb 1, 2005 | 07:51 PM
Vette_DD's Avatar
Vette_DD
Turning the switch above your left knee dims or brightens the dashboard lights (gauges, speedo, tach) ONLY. It DOES NOT brighten or dim the map lights on the bottom of the mirror. In spite of instructions to the contrary in this forum several months ago, DO NOT push the switch in while turning it.
Only push the switch in if you want to turn on or turn off the map lights on the bottom of the mirror.
To interior lights not going off
