C6 Rears Offered
Old 02-01-2005, 09:09 PM
Turbo63
Turbo63's Avatar
Default C6 Rears Offered
I have a C6 with a 3:15 rear -- looks like GM offers others as an option? Can someone explain how the rear selected impacts performance? How does the 3:15 compare to the 3:42 or others that are available? I am ordering a C6 Vert w/z51 -- if I want maximum speed performance what rear do I choose? Does the Z51 already come with a specific rear? Thanks for the insight forum!
Old 02-01-2005, 09:13 PM
vettnutt
vettnutt's Avatar
With Z51 you get the 3:15.
Old 02-01-2005, 09:54 PM
boogieman
Support Corvetteforum!
boogieman's Avatar
Default Z51 Package comes with 3.42 gears
With the higher the gears you get more bite from your rear when launching the car. I had a C5 last year and put a 3.90 rear in the car. It was awesome on the line at Raceway Park. Of course what it really comes down to is what is it that you want the car to do. The higher the gear ratio the higher you RPMs will be when cruising. If you will use your car to do long cruising stick with a gear ratio that not too high. I personally will be changing mines to a 3.90
Old 02-01-2005, 10:32 PM
Juvatpilot
Juvatpilot's Avatar
I think that the Z51 package comes with a variety of rear-end gear ratios. If you get the A4 tranny, then you have the option of selecting the 1:3.15 performance rear end, and your Z51 option will come with that gear ratio. If you elect the MN6 tranny, then you get the 1:3.42 rear-end, whether you select the Z51 option or not. The only other rear-end ratio option is the 1:2.73 which is the standard ratio with the A4 transmission.
The only variation on this theme is that the Z51 option with the MN6 transmission comes with a different set of transmission gear ratios unique to the Z51 package.
Old 02-01-2005, 10:55 PM
vettnutt
vettnutt's Avatar
Old 02-01-2005, 11:17 PM
Vette_DD
Vette_DD's Avatar
Received 1,276 Likes on 935 Posts
Don't think this is entirely accurate. If you get the Z51 handling package with the auto tranny, you get the 3.15 rear axle ratio automatically, no choice. However, if you get the manual tranny, you get the 3.42 rear axle ratio, whether you get Z51 or not, as you indicated.
Only if you get the auto tranny without the Z51 do you get a choice of 2.73 rear axle ratio or 3.15 axle ratio. Then, the 3.15 axle ratio is an extra charge.
Old 02-02-2005, 04:14 AM
LS1LT1
LS1LT1's Avatar
Old 02-02-2005, 01:36 PM
HalM
HalM's Avatar
Back to the original question...a numerically higher number in the ratio provides additional torque multiplication to the rear tires...
Old 02-02-2005, 03:10 PM
Vette_DD
Vette_DD's Avatar
Which tranny are you getting, manual or auto?
Old 02-05-2005, 06:11 AM
Zig
Zig's Avatar
Location: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
Originally Posted by jerrymuniz
With the higher the gears you get more bite from the rear when launching the car. ...
true, lower gears provide a taller top end.
... The higher the gear ratio the higher your RPMs will be when cruising. If you will use your car to do long cruising stick with a gear ratio that not too high. I personally will be changing mine to a 3.90
what are your numbers ? i've got the 3.42, i idle @ 550, 90 is < 2k.
Old 02-06-2005, 09:16 PM
Zig
Zig's Avatar
80 = 1400
To C6 Rears Offered
Quick Reply: C6 Rears Offered
