Ron Zimmer programed my C6
Modified air box, 33-2136 K&N's cut covers flush with filters.
Kooks long tube headers and cats, (no codes)
Magnaflows cat back system
This is what Ron did in terms of tunning:
Set rev limiter to 6850 rpm
added 2 degrees across the board
Limited retard to 2 degrees at higher temps above 200.
trimmed fuel maps.
No cags or fans yet. This is the first program, it's very conserative.
Car runs great! It pulls hard to 6800! Next, I'm putting Jessel 1.8 rockers on. This will bump my cam lift to .556. Also Ron did alot of things that I can't post. Ron also told me that TQ management is not an issue in 6 speeds. I agree because all of my dyno pulls at both magnaflow and superior automotive, the torque line had no dips in them. They were flat and smooth. He did say that it is an issue in autos. Anyway, I'm happy, cars happy. Things are getting better in C6 land.
Andy G.
The first thing I would do after ANY mod it run the car to see how much of an improvement was achieved.
There are so many people out there that spend thousands and really get nothing or little in the way of actual performance increases. I know, because I spent 6k at Champion on my Porsche and actually LOST HP.
Go to the strip and see what she will run!
I have almost 20 runs with my stock C6. I will know for sure if I am making more power once I start to add mods. Too bad Ron can’t tune the Auto’s yet.
714-503-1880 Ask for Joe Jill. As for visual inspection, most likely not, but I'm not worried. It's a factory look install, and they work.
Andy G
Andy G.
the rev limiter?
How do you know that repeated trips to 6800 rpm
won't cause some sort of engine issue? Are you just
feeling lucky?
Pat
the rev limiter?
feeling lucky?
Pat
Jersey
Jersey
keep the engine safe) unless you plan to hit it?
Pat
Andy G
Do you remember the install cost?
I'm trying to estimate a total cost for this mod.
Andy G.
P.S. I don't plan to hit 6800 RPMS It just that I can go solid to 6500-6600 and not bang the limiter. Thats not real good for your motor, because it's a fuel shut-off not ignition, so you go super lean at high R's
trimmed fuel maps.
Andy G.
trimmed fuel maps.
Andy G.
Yeah, ok.
Aren't these two statements in agreement, not disagreement?
Aren't these two statements in agreement, not disagreement?But what I don't understand is how TQ management would be applied in an MN6. Does the PCM know when you push in the clutch and shift at or near redline and pull timing at that instant? I'm not sure if that could be done. This is not as simple as a computer that controls upshifts in a car with an automatic transmission. This also does not explain how some members ran 12.5's in MN6 equipped C6's while others claim that TQ management limits their MN6 cars to 13 second quarters
