Engine & Chassis Tuning
Old Feb 16, 2005 | 12:28 PM
ross_hanna04's Avatar
ross_hanna04
Default Engine & Chassis Tuning
I was just curious to know, what exactly is engine and chassis tuning? Also, what are the pros and cons between both of them. Any information would be great. Thanks.
-Ross
Old Feb 16, 2005 | 12:47 PM
Mighty-Mouse's Avatar
Mighty-Mouse
Chassis tuning is changing the characteristics of the chassis without major modification.
Basically, it's calibration at least from an engineering view-point.
For instance:
-Wheel alignment settings
-shock absorber valving
-anti-sway bar stiffness
-spring stiffness
-brake bias
If you start changing suspension mounting points, changing control arms or brake calipers, etc. Then you're not tuning, but modifying.
Modification and Tuning have become morphed lately.
In the most basic form, Tuning is playing with what is already there without adding or removing anything.
You can do that with software, but in practical terms you would switch out springs, anti-roll bars, shocks, bushings, brake rotors and brake pads.
Pros are that you end up with a better handling and feel. The cons are it takes time and costs money and if you get it wrong you end up making things worse.
