I have a Z-51 coupe. I have the brake ducting for the rear brakes. On the front the ducting stops in the wheel well at what looks like a coupling for the ducting. Does anyone have ducting from the wheelwell to the rotor from the factory? If so do you have pics?
From: Huntington Beach Ca 1 out of 4 Americans are mentally unstable, so if 3 of your friends are OK . . . .
St. Jude Donor '05
Carl
Nope. I noticed that too. The current set up just blows air in front wheel well area. Looks like an after market part might be in order.
You can buy a front brake cooling duct kit from Doug Rippie Motorsports, or Parts For Your Car (pfyc.com). Both are forum sponsors and both are good folks. With the DRM kit, you can either attach the flexible hose to the upper control arm, or use the Phoenix spindle bracket and place it right at the rotor. No doubt the spindle bracket is more effective, but I expect you get 90% of the cooling effect without it, as you can run the hose to within a few inches of the rotor. The only disadvantage with the Phoenix bracket, is that it turns with the spindle, so the hose is constantly flexing; great for a track car, but I'm not sure it's necessary on a street car that does only occasional casual track duty. Either way, you can spend a whole weekend with brake plumbing! But, it's worth it.
From: Muncie, Indiana ...... Can I buy an amplifier on time ... I ani't got no money now but I'll pay you before I die
The factory duct is probably adequate for pure street use, as no duct at all is okay in that environment. But for the track, you really need a duct that directs a concentrated air flow on rotor; just depends on your use.
They actually use two types of ducts on the C6. For the Z51 the end of the duct is open. For the standard and the F55 the end is restricted like this one.
This is shown briefly on the '05 C6 DVD provided with the brochure as something that was developed/tested during the Nurburgring run(s). Engineer's played with this duct to achieve the best cooling. Based on the video, I thought all were the restricted type (higher jet flow thru the "nozzle") but I have to believe the Junkie that Z51's have the full sized hole...
as I am retrieving this "info" from my old senior brain.
But, I SEEM to recall that during their test GM found that with the ducting "opened up"(no restriction) they lost "a" quanity of downforce.
Hence - the "built in" restrictors. I guess that in the real world GM felt that the Z would be driven harder than a "std" and would need the added flow to the brakes. It was a trade off between brake fade or front end lifting. So - now, when your front end sheds the surly bounds of earth you can at least be thankful your brakes will be cool during re-entry!
actually the material you are refferig to is the legand reborn show from the learning chanel. as for what happend they put the smaller opening part on and found to much heat and decided to go with the larger opening and make it up with aerodynamics
Corvettecarl,
We thought the same thing back in 97 when we saw the C5 brake duct. Where is the rest of it? Well we went to the track and after a short time with Doug behide the wheel, the brakes were cooked. There was many other heating issues also, but I wouldn't talk about that now.
So we went to work on a peice that went into the factory duct. Then into a flexable 3.5 inch duct and to the rotor. We only had one sent back with the hose end not being secure. So Lou @ LGM and Joe @ Phoniex have built spindle ducts to finish off the project. With this combo you will have cool brakes, which will save on $$$$ and time spent on the brake maintance.
Then our first C6 came into the shop. Same thing again! Where is the rest of brake duct? So we made a C6 setup also! 199.95 is the cost and you can buy them from us direct or PFYC.com.
This is strickly an assumption...probably something to due with the caliper being in the rear of the rotor and the front suspension being an articulating setup...duh...as in turning wheels I am suprised some after marketer hasn't come up with a fixed duct (like the rear) and directs more of the air to the caliper.
Michael
Michael
The C6 could have come up with a direct front duct like this one:
They used the opened duct on the Z51 to achieve the cooling since they are more likely to see track time. Went with the restricted duct on the standard and F55 to help attain the .286 Cd they like to advertise.
