Any lists going yet on what stuff can be yanked off the C6 (within reason) to shed 200-300 lbs? I read in Road & Track that they added lots of sound deading junk in the C6 to try and get it to luxury car noise decibel levels.
From: Muncie, Indiana ...... Can I buy an amplifier on time ... I ani't got no money now but I'll pay you before I die
If I remember right if you took all the sound deadening material out that would give 7 lbs of weight loss.
September 2004 Road & Track,pg.75: " In developing the sixth-generation Corvette, a 7 percent increase in the weight was allowed for acoustic packaging that includes a full length blanket on the backbone tunnel". Gotta be a lot more than 7 pounds you can reasonably shave off a C6.
Aftermarket wheels and exhausts are almost all heavier than stock. You can drop weight will full length headers however. For an idea of how much weight can be lost, and where it can be lost, check this out:
...lightweight forged alloy wheels and non-run flat tires ..."unsprung" weight .
I would also like to konw, for my own education, how much lighter is the Corsa cat back system than the original?
Don’t know the exact #s but on the tires alone I’d bet 5-7lbs per tire. Magna Flow Cat Backs save 15 lbs over stock. Corsa is heavier than stock.
Don't mean to be a thread hijacker...but the thing that I'm thinking about is not so much shedding a lot of weight but moving some around. Those little storage bins in the back look like a great spot to put a sealed battery and solve three problems at once...the weight distribution improves (handling improves); the weight goes down, and the potential for acid getting on underhood components goes away...
if you get ultra light wheels, saving 7-8lbs per wheel then you might be able to save a lot, since the wheel is considered rotating weight, it accounts for more than 100% of the reduction..i dont know the exact formula, but i know the 40lb you drop in wheels can equal more than 100lbs of stationary weight..
Here is your answer..
My RG18 wheels weigh in at 18lbs each.. that is a 7lb drop from the fronts and 8lb drop from the rears. That is a 30LB drop from stock in Wheels ALONE. Then switching from the Runflats to Toyo T1S tires will save you another 7lbs per corner for a total Unsprung weight savings of 58lbs. Using the formula of 4:1 Unsprung:Sprung, that alone will save you in essence 230+ lbs of sprung weight. Its not an exact science but its close. Then if you wanted to go even further, I also have Stoptech or Brembo BBK's which weigh in about 30lbs lighter then the OEM setup total. Again if you want to use the 4:1 ratio thats another 120lb loss. You stand to lose about 350lbs of equivalent sprung weight by starting at the 4 corners..
Contact me for more information and for pricing if you are interested in any of these as i carry them all. Especially the wheels (best starting point).
Daemon,
I don't see how you can save 30 lbs with a brake kit. The calipers only weigh ~16 lbs without pads. The rotors are ~86 for a full set of C6 Z51 rotors, and ~66 lbs for C5 rotors. I'm sure you use 2-piece rotors with an aluminum hat, but damn near every race rotor I've seen is heavier than stock, not lighter...and then you add the weight of the hat. Also, let's not forget that even if the rotors end up weighing the same, the 2-piece rotors will carry more weight on the outside, which will make it worse because it'll create a higher (polar) moment because the rotational weight is further from the center. For comparison, completely titanium rotors weigh ~20 lbs. The rest of your data looks okay, but I had to call you out on the brake weight information. If you weigh the stock and Stop Tech/Brembo components yourself, and post the results, I'll back off, until then, I still have lots of weights and measurements here: http://forums.corvetteforum.com/showthread.php?t=984927
For my next update of that thread, I'll post weights for the rotor candidates I mentioned above, for the C5 and C6, plus whatever information you may provide.
Daemon,
I will go back and double check the numbers.. The wheel numbers are completely accurate as i have broken the weight down Piece by piece.. The brake figures were general based on experience with a 4 corner setup and a stoptech or brembo kit. I also have a fact sheet from brembo signifying weight savings per vehicle with the installed kit. Using a floating rotor setup on an E46 M3, after removing the dust shields and weighing the calipers and stock rotors, the brembo's came in at 9.5lbs lighter per corner in the front and 5.5lbs lighter in the rear for a total of 30lbs.. i appreciate the numbers and will update the fact sheet i have from brembo as it appears to be complete BS.
