Access to headlight area
Old Feb 20, 2005 | 07:13 PM
Dakota Slim's Avatar
Dakota Slim
Default Access to headlight area
Just got a new C6 and have a rather odd question. There seems to be a small piece of tape or clear plastic in the passenger side headlight. This is the area that is covered by the clear glass. Before I take it back to the dealer, is there an easy way to get access to this area?
Old Feb 20, 2005 | 07:27 PM
German_C6_Driver's Avatar
German_C6_Driver
Check this out... in the 7th post you'll find a pic of the inside of the wheel well looking forward.
http://forums.corvetteforum.com/show....php?t=1019780
Old Feb 21, 2005 | 03:13 AM
skatemic's Avatar
skatemic
I have the same problem in the passenger side head lamp. I decided it wasnt worth having the dealer take it apart for that. They might create more problems when they take it apart. please post if you find a easy way to do it yourself!
Old Feb 21, 2005 | 09:12 PM
C64RT's Avatar
C64RT
Navigator
Default Headlamps
The headlamps are sealed, well sort of, they let air and moisture in but you can't get in there unless you pull out the complete assembly and use a pair of loooooong forcips to latch on to it through the headlamp bulb opening. My guess is the dealer will replace it.
Old Feb 21, 2005 | 09:38 PM
Dakota Slim
I tried the access through the wheel well. As far as I can tell, it allows access to the back of the lights to change bulbs but I cannot see how it lets you get to the painted area in front of the lights. I did take this rubber cover off and removed the rubber cover to the back of the lights. All I could see was a small gap that was almost impossible to get anything in to remove the item. I even tried some high pressure air to at least move the thing out of the way so it was not so conspicuous - no luck. If I am missing something, please tell me, it is bugging the heck out of me but I hate to let the dealer mess with a replacement.
Old Feb 22, 2005 | 04:31 AM
C6FirstVette's Avatar
C6FirstVette
I think the only way to get where you want is to demount one of the light assemblies from the housing and in looking at the back of the housing>>>
I can even see how to do that...I don't think you want to go there considering you might end up breaking something I let dealership do that...then it is on their ticket
Michael
Old Feb 23, 2005 | 01:48 AM
LS WON's Avatar
LS WON
Default so this is why we have to send the car into a dealership when the low beams go out?
Michael
To Access to headlight area
