nitrous
Old May 10, 2005 | 11:42 PM
FLC6's Avatar
FLC6
If you have a window switch the spray will shot off when the butter fly valve closes.
So no worries about TM and N20.
Old May 11, 2005 | 12:07 AM
ttomczak's Avatar
ttomczak
St. Jude Donor '06
Originally Posted by sick_vette
I don't remember which vette mag this month did an article on a c6 with spray. They hooked up a 100 shot to a bone stock c6. The car made 450/600. Or something like that. But it was the torque that was crazy. 240 ft/lbs increase The ecm could not handle the 125 shot however.
Not bad for under $1000. I have had a 100 shot on my c5 for going on three years. It's like anything as long as use don't get greedy and abuse it. By the way I have never heard of someone blowing a motor with only a 100 shot(wet)
When I get a c6. I will have it hooked up first week.
It is the June issue of Vette, they did a 75/100/125 (or 150), the 100 rocked their world, it was a bone stock auto C6, they used the Cartek module and some kind of gas enhancer, plus new plugs...
The numbers posted were about right on... Find this issue (sorry, I have mine packed or I would scan and email it to you)...
It detailed the whole install and the number were VERY impressive...
Thomas
Old May 11, 2005 | 12:23 AM
c6nut's Avatar
c6nut
I did my C6 with a 100 shot wet kit. Did the 3000-6000 pill switch (a must). Works great. No problems with the engine or clutch. I have sprayed about 4- 10lb bottles so far. Runs like a champ. We did the NX N2O system with new plugs and a Corsa exhaust. My numbers on the dyno were 455 RWHP and 484 FT-LB of torque. I am hoping to run at the track this weekend in the 11's.
I don't know where you live but Speed Inc. did my car and they do sell the kits. http://www.ls1speed.com/
Tom from Speed Inc did his C6 with a 150 shot and ran an 11.3 1/4.
Ted
Old May 11, 2005 | 02:48 AM
SpinMonster's Avatar
SpinMonster
Originally Posted by Racetronix
The C6 system is pretty much the same as the late model C5 system. The fuel pump is a PITA to get at as the transaxle must be removed in order to get the DS tank out. The FSU is no joy to re & re either.
I never removed the tank when I installed your awesome pump on my C5. If it has to come out on the C6 then so be it....is the c6 system available?
Old May 11, 2005 | 10:26 AM
FLC6's Avatar
FLC6
I can't find a good Vette shop in South Florida to do a Dry kit for me
Old May 11, 2005 | 11:31 PM
Tommy D's Avatar
Tommy D
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
St. Jude donor in memory of jpee '14
Originally Posted by SpinMonster
Actually the car is very rich from the factory and with 10 degrees less timing than a tuned car....it is very set up from the factory for a spray fest.
Hey SpinMonster,
Just how rich does the C6 come from the factory? I would imagine a stock motor would be running in the neighborhood of 14. something to 1 to meet CAFE regs and emissions
Old May 15, 2005 | 04:41 PM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Originally Posted by crabman
A guys signiture I saw said.... Nitrous is like a hottie with an STD, ya wanna hit it but are afraid of what might happen...
Crab - U da MAN
Old May 15, 2005 | 10:38 PM
shopdog's Avatar
shopdog
Originally Posted by patriot
I was waiting for a little more info before installing my dry kit. What about the info suggesting that torque management might close the throttle-body blade during WOT runs to restrict horse-power. Without tuning to eliminate torque management, wouldn't it be really bad if the throttle-body blade closed while you were spraying the engine, or would it just prevent the nitrous from entering the motor? I was planning on spraying a 75 dry shot. I wonder how many people are spraying these cars without tuning?
Nitrous systems, good ones anyway, are throttle position triggered. They won't spray unless the throttle is at WOT.
Old Jul 11, 2005 | 12:56 AM
Racetronix's Avatar
Racetronix
Supporting Vendor
Yes, but it must be installed by a qualified shop.
Removal of the sender requires advanced skills in a C5/C6 with a top-loaded fuel module.
