Big injectors in LS2-PLEASE HELP
If anybody has the fix, please let me know ASAP!
david.farmer AT metricchemical.com
"If you swap the LS2's 33-lb/hr injectors for a set of GMPP ASA-series crate engine 36 lb/hr injectors you might be better off .
This is because the older style injectors use standard LS1-type injector plugs (the ASA injectors are actually the same as those used on the L67 supercharged 3.8L V6 engines)."
On a side note, "if you swap out your C6 intake and 90mm throttle body with a '04 LS6 manifold with its 76mm throttle body you may pickup 8 HP and 16 lb ft of torque."
The above statments are direct quotes taken from Katech and are found in the April 2005 Hot Rod magazine article" GM 6.0L LS2 Dyno Proven Upgrades (ktechengines.com)
PLEASE TAKE A MOMENT TO VISIT OUR WEBSITE AT WWW.AACORVETTE.COM
NOW PARTNERING WITH AFFIRM TO OFFER INTEREST FREE FINANCING!
ANDY GREEN- OWNER/ CEO -A&A CORVETTE / A&A SUPERCHARGERS
477 LAMBERT ST
OXNARD CA 93036
WWW.AACorvette.com
A&A CORVETTE SUPERCHARGER SYSTEMS
HOME OF THE WORLDS FIRST
CENTRIFUGALLY SUPERCHARGED C7
SUPERIOR ENGINEERING- SUPERIOR POWER
SUPERIOR PRICING- SUPERIOR CUSTOMER SUPPORT
Andy@AACorvette.com 805- 278 4107
