Torque setting for lug nuts?
Old Mar 16, 2005 | 07:51 AM
hlcptr's Avatar
hlcptr
Default Torque setting for lug nuts?
I did a search but found nothing. Does anyone have the correct torque setting for the lug nuts on a C6?
Thanks.
Old Mar 16, 2005 | 07:57 AM
Europa's Avatar
Europa
100 ft lbs.
Old Mar 16, 2005 | 11:45 AM
Scissors's Avatar
Scissors
☠☣☢ Semper Ebrius ☢☣☠
Cruise-In IV-V-VI-VII Veteran
St. Jude's Donor '06
Hit them all in a star pattern while everything is cold and lifted off of the ground. Do four cycles at 25, 50,75, and finally 100 ft.-lbs.
Old Mar 16, 2005 | 05:15 PM
Virt's Avatar
Virt
Thanks.
I recently put some locks on my wheels and had to ask the same question. Be aware that doing it cold is really important. If you do it after a good drive the lugs may have tightened to 115+ lbs or more.
Old Mar 16, 2005 | 05:40 PM
LS WON's Avatar
LS WON
Default This is an easy thing to do right?
Just remove one lugnut and replace with the wheel lock. No balancing of weight of lock necessary???
No jacking involved just need tire iron. In manual it says 100 lbs.
Old Mar 16, 2005 | 06:04 PM
Asterism's Avatar
Asterism
Thanks.
owners manual, page 5-94. 100 ft/lb as previously stated.
Old Mar 16, 2005 | 10:10 PM
KeepItReal's Avatar
KeepItReal
7th Gear
No its 100 lbs.... enough already!
Old Apr 20, 2005 | 03:55 AM
bugman's Avatar
bugman
Hey -- what size lug wrench do I need?
too lazy to just go out and try -- if anyone knows on the top of their head, let me know
Old Apr 20, 2005 | 07:22 AM
Seatrend's Avatar
Seatrend
Since the lugnuts are part of the wheel appearance,.... any tricks to avoid scarring the lugnuts ????(besides using the proper size socket of course).
Old Apr 20, 2005 | 08:10 AM
Scissors's Avatar
Scissors
Paper insert.
Old Apr 20, 2005 | 10:42 AM
vettnutt's Avatar
vettnutt
I got a set of impact sockets that are nylon coated on the outside and have a nylon insert inside to protect the lug and wheel. Harbor Freight for about $22 for the set.
Old Apr 20, 2005 | 11:24 AM
tblackj's Avatar
tblackj
I think they are 19mm, I think, I could be wrong... probably am wrong.
Old Apr 20, 2005 | 11:33 AM
DP Dave's Avatar
DP Dave
Same here!
Old Apr 20, 2005 | 11:57 PM
bugman's Avatar
bugman
Thanks, buddy -- bought a lug wrench today and you were right.
19 mm -- Or 3/4"
They're very close to the same [3/4" = 19.05 mm]
Now I've got to find a good jack and some locking lugnuts.
To Torque setting for lug nuts?
