2k4 Z06 5th gear question
Old Mar 18, 2005 | 04:33 PM
derrick_baxter's Avatar
derrick_baxter
Default 2k4 Z06 5th gear question
Pulled off the tun using EFI Live for my boss ( friend also )
While going through checking everything I ran across this in the rev limiters. Is this normal or a big OOPS by GM?
NOTE 5th gear at 8000????
Not positive if the Z06 can take 8 grand stock during a run, but if just messing around reving the engine in 5th could have done some damage?
Sure glad efi has the 2d and 3d charts made something like this stick out big time.
Resetting to the same as the rest of the gears.
Anyone else ever see this?
1st gear 6600.000000 6599.023438
2nd gear 6600.000000 6599.023438
3rd gear 6600.000000 6599.023438
4th gear 6600.000000 6599.023438
5th gear 8000.000000 8000.000000
6th gear 6600.000000 6599.023438
7th gear 6600.000000 6599.023438
8th gear 6600.000000 6599.023438
no in gear gear 6600.000000 6599.023438
reverse gear 6600.000000 6599.023438
Old Mar 18, 2005 | 04:41 PM
derrick_baxter
The ETC Controlled RPM completely Opposite of what the Fuel Cut-off Limit was, 5th gear again completely different then the rest?
I know my SS and GTO dont do have this 5th gear difference?
9000.000000
9000.000000
9000.000000
9000.000000
6600.000000
9000.000000
9000.000000
9000.000000
9000.000000
9000.000000
Old Mar 18, 2005 | 09:30 PM
Vette_DD's Avatar
Vette_DD
Derrick,
You might try posting this in the C5 Z06 section. I think you said you have a 2004 Z06, or at least you're asking about a 2004 Z06, right? You'll probably get more responses in that section.
Old Mar 19, 2005 | 09:18 PM
derrick_baxter
Doh!!!
To 2k4 Z06 5th gear question
