160 thermostats
Fred
Do realize that the fans don't come on until 215F. A thermostat only sets the *minimum* engine temperature of a fully warmed up engine. It can, and will, run hotter than that depending on load and on the amount of available cooling airflow through the radiator.
Why would it take longer? Assuming you have a fan module to turn fans on properly for a 160 thermostat, wouldn't your operating temp be 160? +/- ?
Although Ed at LPE told me that they make there best dyno pulls at 160 Degrees. My C5 and now my C6 both run when warmed up at between 180-185 on the road. My oil temp is at between 199-214 depending on the type of driving I'm doing. Highway driving oil temp is 199-203. So the oil is getting hot enough to clean the engine, and the proof is my tear down of my C5 LS1 engine. BTW according to my tunner Ron Zimmer and Ed at LPE If your gas milage doesn't take a dump it's not to cold. With the hotter stock stat I was getting 27mpg on the highway and now with the 160 stat running at 180, I'm getting 29.1 highway. I think you run the temp where you personaly feel comfortable with. I'm thinking when all of us see summer comming for the first time with these C6's, these cars with stock stats will see much higher temps. Not that thats bad. But remember GM had to set these cars up for the general population, not just us gear heads who want finite performance. Again According to Ron and Ed these cars are very heat sensitive and they pull timming when they get hot. Anyway you decide!
Andy G.
Although Ed at LPE told me that they make there best dyno pulls at 160 Degrees. My C5 and now my C6 both run when warmed up at between 180-185 on the road. My oil temp is at between 199-214 depending on the type of driving I'm doing. Highway driving oil temp is 199-203. So the oil is getting hot enough to clean the engine, and the proof is my tear down of my C5 LS1 engine. BTW according to my tunner Ron Zimmer and Ed at LPE If your gas milage doesn't take a dump it's not to cold. With the hotter stock stat I was getting 27mpg on the highway and now with the 160 stat running at 180, I'm getting 29.1 highway. I think you run the temp where you personaly feel comfortable with. I'm thinking when all of us see summer comming for the first time with these C6's, these cars with stock stats will see much higher temps. Not that thats bad. But remember GM had to set these cars up for the general papulation, not just us gear heads who want finite performance. Again According to Ron and Ed these cars are very heat sensitive and they pull timming when they get hot. Anyway you decide!
Andy G.
By opening at a lower temperature, the 160F thermostat allows heat to start being dumped to atmosphere before the engine reaches full design operating temperature, thus it takes longer for the engine to get up to its equilibrium 190F operating temperature. The only ways to make the equilibrium temperature lower are to reduce load on the engine, increase radiator size, or increase airflow through the radiator. Once it opens, the thermostat is completely out of the picture.
Now, if you only take short trips, air temperature is low (winter), etc then the engine may not have a chance to reach design temperature with a early opening thermostat. Then you will run into driveability problems, poor fuel economy, high emissions, and sludge formation.
This is going to be a little bit of a book, but that's what it takes to describe this operation.
The thermostat is the brain of the cooling system. Just like the computer is the brain of the engine. The thermostat is designed to regulate the flow of water in order to maintain a desired temperature depending on the temperature rating of the thermostat. When the engine is cold, the thermostat is closed and prevents the flow of coolant out of the engine in order to warm the engine up quicker. Once the engine coolant reaches the operating temperature of the thermostat, it starts to open to permit the flow of coolant through the engine and radiator. Air moves through the radiator and absorbs the heat which in turn cools the coolant. The cooler coolant now starts to leave the radiator and go back into the engine. If the coolant is colder than what the thermostat is rated for, then the thermostat moves toward the closed position in order to restrict the flow until the coolant warms up. If the engine is under load, high power, etc, then obviously it will be putting out more heat. The thermostat now opens more to increase the flow of coolant in order to cool the engine. The thermostat will continue to regulate the flow of coolant by slowly moving towards the open or closed position in order to maintain the rated temperature of the thermostat. As situations changes, primarily the outside temp, speed, and engine load, the thermostat will continue to regulate the flow of coolant accordingly in order to maintain its rated temperature.
For the below example, lets use the stock thermostat which will be 194 degrees.
Say, for example, if the outside temp suddenly goes from 100 to 50, that much cooler air will be going through the radiator. That coolant that is in the radiator will now be colder than previously. So when it leaves the radiator and goes to the engine, the thermostat will sense change in temperature. The thermostat will start to move towards the closed position in order to slow the flow down which will heat the coolant back up in order to maintain 194 degrees.
Now lets do the opposite of the above example. Say if the outside temp suddenly goes from 50 to 100. The thermostat is already more towards the closed position because of the cooler coolant entering the engine and the flow has to be slow because it has to heat it all the way back up to 194 degree. Now, as the hotter coolant enters the engine, the thermostat will sense the change in temperature and will start to move towards the open position in order to increase the flow through the radiator in order to maintain 194 degrees.
This opening and closing of the thermostat happens continuously as to maintain the temperature that its rated for as differences in outside temp, speed, and engine load change.
The vettes cooling system, (thermostat, radiator, and cooling fan), are DESIGNED to work TOGETHER as a MATCHED set. I believe the stock thermostat is 194 degrees F.
If the coolant moves too quickly through the radiator, then it will not have time to dissipate the heat into the air before going back into the engine.
Now, this is what happens when people change to lower temperature thermostats:
First of all and to make it clear again, the thermostat isnt just a simple on and off switch or is something that's just there to warm the engine up and then no longer plays any further role. Its a thermostat, and implies just what the term means. It continually moves toward the open or closed position in order to regulate the flow of coolant to maintain its designed temp rating. Just like the thermostat in your house, if you have it set to AUTO, then it will control the heater and a/c in order to maintain whatever temp you have it set at.
If you install a 160 thermostat, the engine will warm up just as quickly but only to 160 degrees initially. When the temp reaches 160, the thermostat will start to open to start the flow of coolant through the engine and radiator. As the engine continues to warm up, so does the coolant. The thermostat tries to maintain its designed temp rating by opening more to increase the flow into the engine to cool it down to 160. But the radiator wasn't designed to cool the coolant down that low. So as the coolant flows through the radiator, its not cooled enough by the time it leaves the radiator and goes back into the engine. So now the coolant in the engine continues to increase in temperature, so the thermostat senses the hotter coolant that was inadequately cooled by the radiator, it opens even more to increase the flow to cool it back down because the engine temp is increasing. But again the radiator wasn't designed to cool the coolant down that low. So now the thermostat is fully open and trying to cool the engine back down to 160 but it cant. And because of the thermostat now being fully open to allow more coolant in the engine in an attempt to cool it back down to 160, the flow through the radiator is too fast and cant dissipate the heat quick enough before entering back into the engine. This is why the engine temperature is always hotter when putting in low temp thermostats because the radiator isnt big enough to cool the coolant down that low. So most of the time youre running around with the thermostat fully open and the engine temp just varies all over the place with no consistency whatsoever because the flow of coolant is basically straight through at this point and the thermostat is unable to do its job. This is also why you read about people who put lower thermostats in and complain that it never runs at that temp and runs about 20 degrees hotter.
The cooling fans are only used when sitting still because there isnt enough airflow through the radiator. And yes the on/off settings will need to be adjusted if you insist on installing a lower temp thermostat and want to maintain the engine temp in that area.
The lower thermostat you put into your engine, the larger radiator you will need to compensate. A correctly designed and matched cooling system in a vehicle will be able to maintain the temperature of the thermostat regardless of the outside temperature, speed, or load being put on the engine. You dont want to run too cold of a thermostat because you want the oil to get to at least 190 to burn away any moisture, contaminants, etc. Me personally, I just stick with the stock thermostat (194 degree) and have the fans set to come on at 195 and I seem to make plenty of power just fine. See sig. My engine also maintains that exact 194 temp regardless of the outside temp, load on the engine etc. because its a matched setup. It will run more fuel efficient, emission efficient, and be internally cleaner.
I hope all this wasn't too confusing, I tried to make it as clear as I could.
Yes if you think of liquid as discrete parts then you could say part a of the liquid is not getting heated as much when it's moving faster, but your forgetting that your seeing much more part A's with a faster moving liquid also.
Let's say you double the speed, so now part A of the liquid only stays in engine half the time as before, but part A also now gets back to the engine twice as fast. So if we think of liquid as singular parts you can see that it's still going to be cooling about the same, but in actuallity faster moving liquid cools faster and here's why. Water is not in discrete parts, if you move the liquid faster through the engine you are getting more water surface area to touch more engine surface area per second. This is a good thing, because the larger the surface area of the water touching your engine the more heat it can absorb.
Now I don't disagree that your temperatures may not go down with faster moving water, but the reason is that you may already be at the limit of the cooling ability of your radiator. Radiators can only cool so much heat per airflow through them, and if you're already at that limit then moving more hot water through them will just make the radiator hotter.
If you're not at the limit of your radiator then you should get lower temperatures.
At least that's what I've seen from water cooling my computer over the years.
Second, heat rejection to the atmosphere is a function of the temperature difference between the water flowing in the radiator and the air flowing across the radiator. The greater the temperature difference, the greater the amount of heat which will be rejected to atmosphere (it is actually a 4th power function). For an efficient radiator, you want to maximize the difference between coolant temperature and air temperature so that the maximum amount of heat will be transferred from the coolant to the atmosphere. This is one of the reasons modern cars run hotter thermostats, to increase radiator efficiency.
Note that temperature and heat aren't the same thing. Temperature, measured in degrees, is a measure of random (thermal) molecular motion. Heat, measured in calories or BTU, is a measure of system energy (in this case, waste energy we're trying to remove from the engine). An electrical analogy is that temperature is voltage and heat is current. The hotter the coolant, and the cooler the air, that are in immediate contact via the radiator, the greater the heat transfer you get. (Same as the greater the voltage across a resistor, the greater the amount of current which will flow through it.)
For best heat transfer efficiency, the inlet and outlet coolant temperatures will be close to the same. The greater the inlet to outlet temperature drop, the lower the radiator's efficiency at coupling heat to the atmosphere will be (because part of the radiator will be at a lower temperature with respect to the atmosphere, and can't transfer as much heat to the air as if it were nearer inlet temperature).
Coolant flow only matters in so far as it needs to be fast enough to keep the coolant temperature in the radiator high, and air flow through the radiator needs to be fast enough to keep the air in contact with the radiator cool. In other words, increasing coolant flow in the radiator doesn't reduce heat rejection, it increases it. Same as increasing air flow increases heat rejection to the atmosphere. This is fortunate since when we floor the throttle, engine speed increases, water pump speed increases, and water flow through the radiator increases just when we need to reject more heat to the atmosphere. Vehicle speed does the same thing for us on the air side, the faster we drive, the more air flow there is, and the greater heat transfer to atmosphere we get, again just when we need it most.
The notion that increased water flow won't allow "enough time" for heat transfer is an old wive's tale. Conducted heat flows at the speed of thermal molecular motion, and that's about 1 mile a second at 200F. Radiated heat moves at the speed of light (186,000 miles a second). Even at 6000 RPM, water is flowing through the radiator at speeds *far* lower than the time required for heat transfer to occur.
The ideal in a liquid cooling system is for it to be isothermal. In other words, it should stablize to nearly the same temperature all the way around the loop. The thermostat helps to set a floor for that equilibrium temperature, and the sizing of the radiator versus the engine sets a ceiling on that equlibrium temperature, provided enough water and air flow are maintained to handle the amount of heat to be rejected.
“””Question: What does the thermostat do?
Answer: The thermostat's job is relatively simple, but extremely important. It regulates the engine's operating temperature. It does this by restricting the flow of coolant from the engine back to the radiator. The thermostat is usually located in a housing where the upper radiator hose is connected to the engine. The thermostat is a valve that is held shut by spring tension. A wax filled thermal element in the thermostat opens the valve. As the engine begins to warm up and the coolant gets hot, the wax inside the sealed element expands and pushes the thermostat valve open. This occurs at a preset temperature (typically 195 degrees F. or so), which is usually stamped on the thermostat itself. The thermostat should be fully open about 20 degrees F. above the rated temperature.
The opening of the thermostat allows coolant to circulate through the engine and cooling system. As the temperature of the coolant begins to drop, the wax element cools off and contracts allowing the thermostat to partially or fully close. Thus, by cycling open and shut a relatively constant operating temperature is maintained.”””
The thermostat MAINTAINS the temperature of the engine. PERIOD
Let me give you a little analogy. If you have a red hot frying pan (this is the coolant) and want to cool it off, putting it into a sink full of water (this is the radiator) for only a second and pulling it back out, it will still be hot as hell. Put it in the sink for a minute, and it will cool all the way down. It’s the same if the coolant is unable to stay in the radiator long enough (due to the flow being too fast because the thermostat is wide open) to dissipate its heat.
And for the record, I have been to the dragstrip eight or nine times in both my C5's and my C6. I have made runs with the water temp at 190 on early runs, and over 225 degrees on later runs, and have seen virtually no dropoff in performance.
