Transmission Issue
I was supposed to bring my car in to B.P.P. for some work but thats not going to happen now. If anyone has any advice on how to proceed from here I sure would appreciate it.
Thanks in advance
Tom...
The other issue - did the clutch stick to the floor during the shift?
Elvy
Elvy
I've driven about 400,000 miles on manual transmissions since 1970 (sixteen (16) times around the world at the equator -- you know, the hot part).
They all behave the same way.
There's the:
1. "Can't get it into first."
2. "Can't get it into reverse."
3. "Can't speed shift into third from second, fifth seems so much easier."
Etc., etc., etc., etc.
Unless there's a real problem with your transmission (and it doesn't sound like there is), I would suggest learning how to drive a manual transmission car for the next thirty years, don't torture the dealer, and then post this again on March 26, 2035.
Let me know what the responses are at that time.
There's the:
w3. "Can't speed shift into third from second, fifth seems so much easier."
try to finesse the shift, try it a tad slower. Also remember that the shifter automaticaly centers itself so third isn't as far to the right as you might suspect.
the not going into first at a stop is a common problem with some manual transmissions. It can also happen if you shift it into neutral to start it and then it won't go into reverse, gotta put it into first, rock the car just a tad then it will align and go into reverse. Just one of those things when it's not synch'd.
ATOMMYD
Also see my post above. We're all trying to be helpful here.
Now imagine the shift plate again. It seems to me that compared to my last several cars that I've driven (because I also never had this problem in any of my other cars), the entire plate is rotated slightly counter-clockwise (towards the driver). So basically in my other cars where I would power-shift into third, in the C6 I'm actually pushing it into the tooth between 3rd and 5th (because it's slightly rotated). So hence I just had to spend about a week training my arm to apply a little pressure to the left when going into 3rd. Felt weird because it seemed as if i was going to go right back into 1st, but it works. Now I do it without thinking and i haven't done the mis-shift again
.Anyways, long description, but hopefully it helps
. I honestly think it's driver error which is what I went through.
. I honestly think it's driver error which is what I went through.ATOMMYD
Also see my post above, and the one directly above this one. We're all trying to be helpful here.
You have to look closely.... very closely.
Keep looking. Closely.
