The difference between LS1 and LS2?
Old Mar 31, 2005 | 09:45 AM
Brannon's Avatar
Brannon
Default The difference between LS1 and LS2?
I love my C6 and I can certainly tell the torque curve is broader. One thing confuses me. My C5 would slam into the rev limiter in 2nd before I even knew what was happening. I had to be more aware of where my RPMs were. On my C6, it seems to not be as peaky and its obvious that a shift is imminent. Is this because of the higher red line?
I know my C6 is deceptively fast. Other than the displacement, what are the differences?
Thanks.
Old Mar 31, 2005 | 12:05 PM
Scissors's Avatar
Scissors
☠☣☢ Semper Ebrius ☢☣☠
Cruise-In IV-V-VI-VII Veteran
St. Jude's Donor '06
Thanks.
The LS2 has more displacement, the 2001 Z06 Camshaft, and much higher compression (10.9:1 vs. 10.1:1). The heads are also different and have a higher flow. And the redline, as you've noted, is higher.
And, yes, the higher redline is probably why it seems to be the way you noted.
Old Mar 31, 2005 | 01:39 PM
Brannon's Avatar
Brannon
Thanks Scissors!
Old Mar 31, 2005 | 02:21 PM
OWENMUSTANG's Avatar
OWENMUSTANG
and note. different intake, 90 tb. different exhaust, air box.
i agree with scissors, hey, what gear did/do you have in the c5/c6?
Old Mar 31, 2005 | 02:44 PM
Brannon's Avatar
Brannon
I have the Z51 and the gear ratio is 3.42, same for my C5.
Old Mar 31, 2005 | 04:07 PM
Ken1234's Avatar
Ken1234
Brannon, can you tell me how you like the 3.42 gears in your c5. I have the 2.73, and want to convert to 3.42. Is it worth it. The cost is about $2,400. Thanks
Old Mar 31, 2005 | 10:29 PM
Brannon's Avatar
Brannon
Ken, I had the 6spd in my C5, but gearing is probably the best bang for your buck for acceleration. So, to answer your question...yes!
Old Apr 3, 2005 | 10:20 PM
fdxpilot's Avatar
fdxpilot
Sounds like highway robbery to me. For C5s, a new 3.42 carrier is $1000-1100, and install is about $500.
To The difference between LS1 and LS2?
