auto trans slips after turning
Old Apr 1, 2005 | 10:04 AM
Bruce C6's Avatar
Bruce C6
Cruising
Default auto trans slips after turning
I've seen this problem posted before but can't find the thread. I have a Z51/auto and if I shift to 3rd and make a right turn at about 40 mph as I accelerate out of the turn the trans slips. It has been to the dealer once and goes back on Monday for diagnosis work. Low fluid was suggestted on the other thread and to the dealer. Thanks for the help.
Old Apr 1, 2005 | 01:42 PM
Corvette400400's Avatar
Corvette400400
From: Horsepower is how fast you hit a wall, torque is how much of the wall you take with you Jacksonville, Florida
St. Jude Donor '05
I believe the forum member datawiz has the problem you are speaking of he has talked about an issue like that a while back, I am not sure of his resolution if any he found.
Old Apr 1, 2005 | 01:49 PM
Corvette400400
St. Jude Donor '05
This is the starter thread from datawiz that spoke of a problem like that:
http://forums.corvetteforum.com/show....php?t=1025901
Old Apr 7, 2005 | 01:11 AM
Bruce C6's Avatar
Bruce C6
Cruising
Thanks, 400/400.
Datawiz has not had time to get his to the dealer.
I got mine back today and the fluid level was fine. There was no code found. They pulled the trans pan and found "stuff" in the valve body. Cleaned the valve body, put in a new filter, and refilled. So far everything seems fine. I'll have to turn fast and accelerate to make sure.
Old Apr 7, 2005 | 09:51 AM
Datawiz's Avatar
Datawiz
CI-7-8-9-10 Veteran
Cruise-In IX AutoX Winner
St. Jude Donor '05 thru '11,'19,'22,'25
St. Jude/CI Name Tag Designer
Originally Posted by Bruce C6
Thanks, 400/400.
Thanks for the info! I'm printing this out. Depending on my schedule, I'd like to get in tomorrow. Let me know how your hard turn test goes!!
Old Apr 7, 2005 | 10:16 AM
dollarbill's Avatar
dollarbill
St. Jude Donor '06-'07-'08-'09-'10-'11
The problem could actually be in the rear end unit. The limited slip differential disengages on one side durring the turn. When you come out of the turn in 3rd, significant power is applied to the drive train. My guess is that the limited slip system is not re-engaging properly and you feel it slip.
Bill
Old Apr 7, 2005 | 11:10 AM
corvettebob1's Avatar
corvettebob1
Bill
This is not the problem and cannot be!
Your limited slip has a clutch pack on both sides that are spring loaded and all it does is allow the wheel with the shortest turning radius to slip that clutch pack.
You could completly wear out both clutch packs and it would still drive like a normal car with an open diff.
Old Apr 9, 2005 | 09:02 AM
RossN's Avatar
RossN
It just happened to me!
Exiting from a highway onto a clover-leaf turn and I really turn in hard at about 45. The car pulled .95 to .96 G's for about a 1 second and I tryed to accelerate at that point, only the engine just rev'ed like it was in neutral. I even goosed the throttle several times and same thing, rev'ing. I coasted down to about 25 and wasn't even turning that hard anymore, maybe about .3 and goosed the throttle again and same thing!
Pretty dangerous if you ask me. It took about another second for the transmission to engage again and everything was normal. From start to end the engine did not propel the car for about 4 seconds with the last second pretty much steering straight.
I wonder if it is a trans fluid issue?
Old Apr 9, 2005 | 08:38 PM
tjfontaine's Avatar
tjfontaine
I too found this problem FRIDAY when I was pulling hard Gs at high speed coming off a cloverleaf ...
BruceC6 - please test yours out as soon as you can to see if that solved the problem - for some reason I don't think it will ... I am wondering if there is a problem with how the trans is programmed.
Those of you with Autos - you may want to try this and if you have the problem too ..
Old Apr 9, 2005 | 09:29 PM
Datawiz's Avatar
Datawiz
CI-7-8-9-10 Veteran
Yes Bruce, I'm waiting for the test results! If your dealer found it, I will be in first thing next week.
Old Apr 9, 2005 | 09:31 PM
Datawiz's Avatar
Datawiz
CI-7-8-9-10 Veteran
Not that this problem is fun to have, but it's nice to see that I'm not the only one having this problem. I too think this is a big deal.
Old Apr 9, 2005 | 09:49 PM
Corvette400400
St. Jude Donor '05
I have been reading about this on and off from datawiz and have tried to replicate it several times. 2 days ago I pulled a hard turn at 47 mph pulled it to .97Gs and then stomped on it after the back end straightened out and the tires chirpped a bit and then just rocketted off to 110 before letting off and not for an instant did my engine rev like that or my tranny not engage. I have tried both in normal mode and competive driving mode and can not replicate this issue. I also have Z51 but I dont see how that makes any difference anyway. Now I see others are having this problem now and it makes me very curious as to what is going on with your cars. I wonder if it could be that the fluid level going through such a high G turn could be shiffting to the point in the tranny that it is not allowing it to engage properly until the fluid level settles out? I hope ya'll figure this out and I hope it isn't a problem that can just start happening because this doesn't sound like a good thing to have happen at all. I guess time will tell until someone out there figures it out and then passes it on.
Old Apr 11, 2005 | 08:21 PM
Datawiz's Avatar
Datawiz
CI-7-8-9-10 Veteran
Bruce C6 said his fluid level was not low so I'm not sure that is the issue. Hopefully he will report back soon on his field trials.
Old Apr 11, 2005 | 08:45 PM
The Garage Master's Avatar
The Garage Master
Happen to me on an on ramp but hasn't happened since. I think its in a relay in between a shift point but my "opinion". I am taking to the dealer tomorrow to have checked.
Old Apr 15, 2005 | 10:26 AM
OWENMUSTANG's Avatar
OWENMUSTANG
any updates?
Old Apr 15, 2005 | 03:17 PM
Bruce C6's Avatar
Bruce C6
Cruising
Hi, Still seems to be fine. More miles will tell. One of the reasons I like new Vettes is I'm no mechanic, but how would turning effect a relay?
Were as fluid (dirt in the fluid) would move with turns
Old Apr 15, 2005 | 11:52 PM
tjfontaine's Avatar
tjfontaine
Bruce - say more - what do you mean by "still seems fine"? Did you try the high speed G force turn as before and NOT have the problem any more? Did you try it more than once?? Inquiring minds want to know.
Old May 5, 2005 | 05:27 PM
Bruce C6's Avatar
Bruce C6
Cruising
Hello, Have not had the problem reoccur, but I have not had many opportunities to drive the car hard. The main reason I'm posting is to bring this back to the top for Richard M.
Old May 5, 2005 | 07:14 PM
blue racer c6's Avatar
blue racer c6
I have not had any problem but my I would think if you are driving the car hard other than a drag strip you would down shift or up or
down shift in to gear for your speed, if it would down shift comming out of a turn into a lower gear you would loose control.
To auto trans slips after turning
