engine cooling fan?
Old Apr 3, 2005 | 07:32 AM
sallen619's Avatar
sallen619
Default engine cooling fan?
At what temperature does the fan turn on? What causes it to turn on?
I've seen oil temps as high as 241 degrees and coolant temps above 220 degrees when I've turned the car off and have never heard the fan come on.
Old Apr 3, 2005 | 11:37 AM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
without the A/C on the fan comes on at 230 degrees
Old Apr 15, 2005 | 11:40 AM
RCoons's Avatar
RCoons
St. Jude Donor '06-'09
Default Engine Cooling Fan
So with the fan coming on at 230, seeing temps in the 210 to 215 range in traffic is O.K. ????
Old Apr 15, 2005 | 12:03 PM
HalM's Avatar
HalM
210-215 is fine...no issue...
Old Apr 15, 2005 | 01:00 PM
clem zahrobsky
Cruise-In I Veteran
i have seen 216 degrees in my C-5s at BG in traffic
Old Apr 15, 2005 | 02:47 PM
MitchAlsup's Avatar
MitchAlsup
Yes, the whole system is designed to enable the engine to run at relatively high temperatures. The oil gets thinner and has lower pumping losses, therefore better fuel economy. Basically, as long as you don't start loosing coolant, the engine will withstand quite high temperatures "with moderate operating parameters"*
[*] don't try running the engine on a race track at 230 dF water and 285dF oil temps for very long.
To engine cooling fan?
