Adding Z51 sway bars.........question...
Old Apr 23, 2005 | 01:16 PM
blittle's Avatar
blittle
Default Adding Z51 sway bars.........question...
1. Can you add the Z51 sway bars to the F55 suspension AND,
2. if you can, is that going to mess up the calibration of the active handling system?
Old Apr 23, 2005 | 01:24 PM
natejohn's Avatar
natejohn
#1. Yes - VERY EZ
#2. No. AH doesn't know what size the bars are, it just measures lean/sway etc. of the chassis/body.
Old Apr 23, 2005 | 01:27 PM
Hoonose's Avatar
Hoonose
Yes, it's been done, do a search here.
It might not effect A/H much, as that system detects wheel slippage, and applies braking at the corner that's slipping. But, I would think GM would know the answer, if they're selling the parts.
Old Apr 23, 2005 | 04:22 PM
Kreuzen's Avatar
Kreuzen
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I added the Z51 sway bars to my F55 suspension. No impact to active handling system. Given the improvement (basically eliminates body roll), probably one of the least expensive performance mods you can make. I recommend it!
Old Apr 23, 2005 | 05:39 PM
crabman's Avatar
crabman
Kreuzen has it right. The only downside to this mod is that it isnt free. It is however cheap and will make the car handle the way it should have in the first place. This should be at the top of any base or F55 owners list. You will be happy. Highly reccomended.
Old Apr 23, 2005 | 06:13 PM
Dash Culpepper's Avatar
Dash Culpepper
Same here
Old Apr 23, 2005 | 07:47 PM
blittle's Avatar
blittle
Thanks guys.........sounds like the way to go.........I'll be ordering mine from Fichter in Montanna.......seems like he has the best price
To Adding Z51 sway bars.........question...
