Adding XM Radio to NAV
Old Apr 25, 2005 | 08:03 AM
Chris A's Avatar
Chris A
4th Gear
Default Adding XM Radio to NAV
Up here in Canada we don't currently have XM Radio and therefore its not available as an option so my question is can it be added/controlled through the stock NAV unit the way it would if it were factory ordered? I'm not concerned with the subscription because I have family in the states and an address won't be a problem.
Any feedback would be appreciated thanks!
Old Apr 25, 2005 | 01:28 PM
shopdog's Avatar
shopdog
If you can get hold of a module, it'll plug in and the Nav radio will recognize it. A junkyard may be your only option to get a module. The wiring for the module should be present, but you'll have to run the antenna wire and install an antenna yourself. The module mounts near the driver's side rear speaker. Open that up and look for the plug before spending any money.
Old Apr 25, 2005 | 02:09 PM
Chris A's Avatar
Chris A
4th Gear
Why would a junkyard be my only source? Couldn't I order a module and it would have new xm id? the antenna wire would come off that module aswell
Old Apr 25, 2005 | 02:17 PM
yell01's Avatar
yell01
CI 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10
I've been wondering the same thing. I don't like the antenna on the trunk lid of my vert so I didn't get XM. Now that I don't have it I miss it when I drive the Vette (my daily driver has it). I'd like to get the module and just mount a micro antenna on the dash or as one forum member who added a Roady unit did, mount it behind the passenger seat.
Old Apr 26, 2005 | 01:16 AM
shopdog's Avatar
shopdog
The problem is that GM Parts doesn't sell the module as a replacement part. A repair part is only available as exchange for a broken unit. So to get a module, you're going to have to get one from a totalled Vette in a junkyard. They do the same thing with the Nav HU, you can't buy one through GM Parts. They only offer an exchange program through Delco for defective units.
I don't *know* what GM is thinking with these policies, but I suspect they do it this way to discourage people from buying a 1SX or 1SA car and then upgrading it to Nav and XM without buying the whole 1SB package. The latter is extremely profitable to GM, and they want buyers to purchase 1SB cars rather than parts of the package piecemeal via the parts counter.
Old Apr 26, 2005 | 02:40 PM
Chris A's Avatar
Chris A
4th Gear
Ya I see what you mean I just came back from the parts counter and found out that its not available as a seperate unit. Time to start searching the wreckers anyone have any suggestions?
Old Apr 28, 2005 | 04:00 PM
yell01's Avatar
yell01
CI 7-8-9-10 Veteran
I might try the C6 parts section. Maybe someone out there got their car with XM and won't pay to subscribe would be willing to sell the unit to make up the cost. Just my $.02.
Old Apr 29, 2005 | 05:25 AM
jazzlove's Avatar
jazzlove
From: San Antonio Texas - Any sufficiently advanced technology is indistinguishable from magic
really too bad... I didn't get XM for same reason. We've got a roady and it works, but I would really like the installed version...
Old Apr 29, 2005 | 06:57 PM
synthtk's Avatar
synthtk
Ditto, I have the roady laying in the center console but it would be nice I had XM integrated into the NAV.
The most annoying thing is remembering to turn off the XM since the center colsole power source is always on.
Old May 1, 2005 | 08:31 PM
Ginny C6's Avatar
Ginny C6
CI 6-7-8-9-10-12 Veteran
St. Jude Donor '11
Does the XM module have to be from a C6?
Old May 2, 2005 | 02:42 AM
shopdog's Avatar
shopdog
I don't know, but I suspect it at least has to come from another 2005.
Old Jul 8, 2005 | 05:46 PM
JERRY4321's Avatar
JERRY4321
Default Adding Xm To Nav System
LOOK AT GINNY C6's THREAD ON PAGE 1 OF THE C6 TECH. HE FOUND A SOLUTION, WHICH I JUST ORDRED. MIGHT BE YUR SOLUTION
To Adding XM Radio to NAV
