Shift light hook-up wire
Old Apr 25, 2005 | 10:16 AM
SpinMonster's Avatar
SpinMonster
Default Shift light hook-up wire
Anyone know where to tap for the tach signal for a shift light? Same as the white wire from a C5 in the dash?
Old Apr 30, 2005 | 04:14 PM
SpinMonster
No one installed a N2O system or shift light? Is the tach wire in the same spot on the C6 as it was on the C5?
Old May 20, 2005 | 12:11 AM
SpinMonster
PCM pin number the same.......white wire......shift light installers...anyone?
Old May 21, 2005 | 09:41 AM
NineBall's Avatar
NineBall
You may just be the first person here to install a shift lite in a C6. Once you figure it out, I might be the second one.
Tony
Old May 21, 2005 | 01:35 PM
Hoonose's Avatar
Hoonose
You do know there's a 'shift up arrow' on the HUD?
You should be able to tap into that somehow.
Old May 22, 2005 | 01:24 AM
SpinMonster
The shift light is in, just not hooked up to the tach signal.....too lazy to open the wheel well
Old May 22, 2005 | 11:25 AM
C7Z51's Avatar
C7Z51
From: Never take a girl out for a cup of coffee, the last thing you want her to be is alert and focused. Tampa, FL
St. Jude Donor '05
There's a shift up arrow in the hud?? Around what RPM does it engage?
Old May 22, 2005 | 01:19 PM
Hoonose's Avatar
Hoonose
At redline. Set the HUD to track mode and see.
Old May 23, 2005 | 08:50 AM
TAG-D IT's Avatar
TAG-D IT
It will come on in street mode also.
P.S. I think it comes on past the beginning of the red on the dash tach.
Old May 23, 2005 | 10:54 AM
C7Z51's Avatar
C7Z51
St. Jude Donor '05
I tried it yesterday and saw the arrow on the hud. Does it hurt your motor to shift when the arrow tells you to at redline(or a little past), or is it better to shift your self before redline. This would be in a race of course.
Eddie
To Shift light hook-up wire
