Under Drive Pulley
Old Apr 26, 2005 | 02:32 PM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Default Under Drive Pulley
Under Drive Pulley
Know that it results in more HP due to less engine strain. Am concerned about A/C, H2O pump, and Alt in summer stop & go traffic.
What do you Gurus say? Yes/No and Why
What is the Cost vs Benefit? I.e. UD Pulley makes 3 HP but runs down battery etc.
Old Apr 26, 2005 | 03:18 PM
andreas g.'s Avatar
andreas g.
Default under drives
I had it on my C5, My engine temps were right at 180, A/C worked in vegas in july, and my volt meter still showed 13.5-14 volts charging at idle. Plus it will net you 8-10 RWHP. Now for the down side, DON'T just do a pulley the labor alone is will run you $800-$1000. It's the same labor for most of a cam change. $ for HP it's not cost effective. It's a no brainer when you do a cam change. Then there's no extra labor involved. Just parts. It will run you about $280 including belts and new bolt.
Andy G.
Old Apr 26, 2005 | 03:53 PM
JFTaylor's Avatar
JFTaylor
St. Jude Donor '06
Andy G.
Good info Andy, thanks. I've seen is as part of a cam package. Understand the labor/install you mentioned. 8-10 is more than I would expect. Good to know that you had no overheat, AC, or Volt probs. And in Vegas, damn. Thanks again.
Old Apr 29, 2005 | 10:24 AM
Flareside's Avatar
Flareside
Originally Posted by JFTaylor
Under Drive Pulley
Do you guys know if an LS1 ASP underdrive pulley will fit the LS2? I've got one here from my C5 that I'll save for the C6 if it fits.
Old Apr 29, 2005 | 12:56 PM
andreas g.'s Avatar
andreas g.
It should, there the same size and distance from point to point.
Old Apr 29, 2005 | 03:07 PM
OttoNP's Avatar
OttoNP
My vote is no, for one thing the voltage regulator on the alternator may just demand more torque which will negate any benefits. Plus, the cost to benefit ratio is not that large.
To Under Drive Pulley
