A4 4L65-E transmission problem
Old May 3, 2005 | 01:19 PM
C64Rick's Avatar
C64Rick
Default A4 4L65-E transmission problem
I posted this in the C6 form and am hoping that someone here might know what the problem is. (Other than driver error).
http://forums.corvetteforum.com/show...60&forum_id=74
In short, when exiting a hard corner, the engine simply revs for a period of time like its in neutral before engaging. This happened to me at the track on Sunday and my conclusion is that the tranny fluid must be dirty, low or both. Any other possibilities?
Old May 3, 2005 | 01:40 PM
Easygoing's Avatar
Easygoing
Hey Rick, It sure sounds like the tranny is sucking air instead of fluid. I wonder if your a little low on fluid???
Old May 3, 2005 | 01:56 PM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
I hope you've still got warranty. Sounds to me like you've got bands about to go. I'd be headed back to the dealer on that one (assuming that since you said C6, you've still got a warranty).
Old May 3, 2005 | 02:23 PM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
I'd be expecting a new transmission, from GM. Don't bother with the fluid...take it to the dealership you've got a waranty still.
Chris
Old May 3, 2005 | 02:29 PM
D C's Avatar
D C
USMC (retired)
sorry for the ignorance, but what do you mean when you say "you've got bands about to go"....what is bands?
Old May 3, 2005 | 02:46 PM
JeepTJ's Avatar
JeepTJ
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
Sounds like your tranny is slipping. Just had mine rebuilt. Kevlar clutches (9 pack) shift kit (transgo) and a 2400 stall torque converter. It's a different beast now. All for just under $2200. Good luck, mine was not in warranty.
Old May 3, 2005 | 03:58 PM
robertpel9's Avatar
robertpel9
perhaps the fluid is sloshing around in there and it is starved.
You need to get this looked at as you are going to burn it up if you have not already. I have heard many other C6 people mention this same problem. I am surprised as isn't it the same tranny and placement that the C5 has?
Get your car to the dealer asap.
Old May 3, 2005 | 06:05 PM
Vettlldo's Avatar
Vettlldo
How is that Torque converter around town? Too much stall? Does the transgo shift kit give you whiplash during mild gear shifts?
Old May 4, 2005 | 07:49 PM
C64Rick's Avatar
C64Rick
Default Status after visiting the dealer
1. They were able to reproduce the problem (God only knows how they did that)
2. Per GM's recommendation they dropped the pan, checked the screen and tube and verified that everything is clean.
3. Per GM, they are aware of the problem and there is no fix at this time
So now I guess I will call GM and see if they will take their car back.
Old May 4, 2005 | 09:27 PM
Vettlldo's Avatar
Vettlldo
The Chevrolet service rep told me yesterday that GM uses a 4L60-E transmission in the C6. Do you have documentation showing a 4L65-E transmission?
Old May 4, 2005 | 10:43 PM
C64Rick's Avatar
C64Rick
From the Corvette Museum's specification sheet http://www.corvettemuseum.com/specs/...wertrain.shtml and any other's that I have seen " The available automatic transmission in the C6 is the new Hydra-Matic 4L65-E four-speed." I checked the owners manual and it doesn't say.
Old May 4, 2005 | 11:25 PM
Vettlldo's Avatar
Vettlldo
Yes...even the write-up in Corvette Quarterly had stated that it was a 4L65-E transmission. Hmmm...
Old May 5, 2005 | 05:21 PM
LS WON's Avatar
LS WON
Default It is the heavier duty version of the 4L60.
What is the mileage on this car?
Old May 5, 2005 | 05:23 PM
C64Rick's Avatar
C64Rick
4100 miles
Old May 5, 2005 | 05:40 PM
Bruce C6's Avatar
Bruce C6
Cruising
Hi Richard, I added to my post to bring it back to the top. My C6 was built in 12/04 (#11630) also. Your describing exactly what mine was doing. I don't think it is TC or AH because these should slow the engine down not let it spin. If my does this again it will go back to the dealer and I'll post. I cancelled out of a driving class in Willows CA because of this problem.
Old May 5, 2005 | 07:27 PM
blue racer c6's Avatar
blue racer c6
? where you driving the car like a manual and down shifting yourself or keeping it in D or 3 .
Old May 5, 2005 | 07:43 PM
C64Rick's Avatar
C64Rick
'D' no shifting
To A4 4L65-E transmission problem
Old May 5, 2005 | 08:02 PM
blue racer c6
Do not know your speed but if it did down shift you might see back end pass the front. run it like a manual 1st is good to 65 mph 2nd good to 95mph 3 have seen 125 mph and stiil not ready to shift to D. If you let it up shift or down on its owne in or out of a turn you are looking for trouble.
Old May 5, 2005 | 08:36 PM
C64Rick's Avatar
C64Rick
When I have an opportunity I'll try some manual shifting.
It was definetly downshifting when entering the turn.
Old May 6, 2005 | 05:35 PM
LS WON's Avatar
LS WON
Default I just leave it in Drive and let it do its thing otherwise I would have got a MN-6
To date I have had no problems with my A-4
