exhuast wrap - anyone try / results ?
Old May 8, 2005 | 08:18 AM
Zig's Avatar
Zig
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
Default exhuast wrap - anyone try / results ?
anyone tried the exhaust wrap "trick". it's old timer / racer trick to reduce backpressure, increase hp, and cool the engine compartment. i've also heard about the complaints of cracked headers, etc due to too much heat retention (seems to be associated to cheap materials and too much wrap). i'm interested if anyone has tried it and if there are any hard and fast numbers.
Old May 9, 2005 | 09:36 AM
smdio's Avatar
smdio
i would also like an answer to this if anyone has tried it
Old May 9, 2005 | 11:45 AM
yellow01's Avatar
yellow01
Don't think you'll find to many that have.
The favorite method these days on aftermarket headers is ceramic coating to reduce heat etc.
Header wrap is great for protecting tie rod end boots from hot rotors though
Old May 9, 2005 | 12:35 PM
wrustywrench's Avatar
wrustywrench
I have seen wrapped header rust and warp due to the extra heat,, use coated. The wrap is great for tie rod boots...
To exhuast wrap - anyone try / results ?
