C6 Oil Consumption
Try switching to Mobil-1 10-30 from 5-30, particularly in the summer months. This tends to help with the oil consumption issue, helps seat the rings, and wouldn't violate any warranties.
When consumption is severe, getting on the dealer's evaluation program is essential. If they determine the consumption is beyond 'normal', and can document the condition, the fix is to pull the engine/heads and replace the rings and wipers. Same as with the LS1 engines. If this condition exists it explains why owners do not see oil leaks in their garage. It's basically "blow-by", or blow through.
Bruce Miller
c5bruce@adelphia
I have an ls2 powered GTO and a ls1 powered vette.
I have not really noticed any oil consumption on the ls2, but I did install a catch can in the PCV line and it seems to be catching a lot of oil.
The ls2 seems worse than the ls1 about sucking in oil via the PCV. That could very well be the source of some of your oil consumption. I doubt it would account for full quart, but you never know.
Also. I would not be too worried about a little oil consumption. It is somewhat the nature of the way these motors are designed. The rings are low tension. It all comes down to how much is too much.
My car at 18,000 miles was using a quart per about 2,000 miles under soft driving. If I drove it above 3k rpms with any kind of regularity, it went way up. The issue was only a problem with 6-speed cars, not the auto trannies, and there was plenty of discussion about why they differ. IMHO, the obvious answer was that 6-speeds by their very nature spend more time at higher RPMs than autos, and I'll add that I thought this car was supposed to be drivable at that range. I'm not talking red-line by any stretch of the imagination, just the upper half of the RPM band. Anyhow, after the arguments, insults by forum members, blame game, and fanfare, I had the fix done. The leakage was then completely gone. Thereafter, I supercharged the car and it ran fine, with no consumption and being driven much harder, for at least 20,000 miles. This included some 1/4 mile racing and roadcourses.
I can't imagine GM would make the same mistake again, but I'd be disappointed with a C6 to know I have to add oil like my buddies used to have to do to their late 60's blue-smoke-blowing Fords.
I'd be curious, for those posting hereafter with or without consumption, please state whether you have an auto tranny or a 6-speed.
I have 1095 miles on my car and the oil low message came up the thing ate a quart and could take another.
What was the cause in your case. I am a little worried with this kind of consumption and thoughts?
Thanks,
Mr. clean
Hi Steve
I had a '01 Vert A4 and never had an oil problem. In Jan I took delivery of my C6 Z51 Vert with 6speed. Had to add 1 qt at 2k and 1qt at
4k the car now has almost 5k and is down 1/2 qt so far. I like to shift
1-2 and 2-3 around 3.5k and seldom get much above 5k rpm.
I am planning a trip in July, which should add 1.5 to 2k miles
if the the oil usage remains the same I plan to take it to the dealer, so I will be following this subject closely......
So far I've had to add 2 quarts of Mobile 1. At my
next service, I'm going to request the dealer start
an oil consumption test.
Pat
I was having a similar thought.
I just did an oil change (@4K miles) with Castrol Syntec and a K&N Filter. In GM's defense, I am somewhat of a leadfoot (have to get past the CAGS, don't'cha know
), so slightly higher than "normal" consumption isn't something I'm going to be "too concerned" about. 1 quart every thousand miles is unacceptable though...And again, I pose the question (or ponder the thought) - just WHAT did Exxon/Mobil actually DO for Chevrolet, in order to put all those nice Oil Filler caps on thier cars?
Regards,
Rick
You would think they would get it right by now
Happy Independence Day All.... Be Safe
My 04 Zo6 is not a daily driver but gets some rather high rpms rides on the weekends, so far it has not used a drop.
This issue is why alot of folks shyed away from the 2001 Zo6. To my knowlegde it was not an issue for the ls1 (read coupe or vert C5s).
I really hope its not an issue in the LS2, I don't care what GM says about oil consumption, I don't like the idea of paying alot of money for a NEW car and having it eat oil like I've been racing it for 150,000 miles. Although it some oil consumption is normal a quart per 1,000 miles is not a realistic number. IMHO if you change your oil every 3,000 to 5,000 miles you should never have to add oil. I check mine regularly to watch just this issue, I start burning a quart evry 1,000 miles and GM will be doing a rering, but to my knowlegde the oil consumption issue on the LS6 was fixed in 2002
I did the 500 Mile break-in as recommended (or at least I TRIED). Generally driven mildly (upshifts @ 3-4K RPM), but I do jump on it frequently. 50/50 in-town & "fast" hiway miles so far. It's definately not "baby'd", at least as far as the gas pedal goes.
No visible leaks in the engine compartment, or garage floor.
What's the "average experience" around oil consumption with the LS2 motor? Is a quart in 4K miles something I need to be concerned about? Or is this common for the break-in period?
I came out of an '01 Suburban 2500 with the infamous "Vortec Cold Piston Slap", that consumed a fair amount of oil, but that was due to poorly designed piston skirts.
Just curious what oil consumption patterns others here are seeing...
Regards,
Rick
SickRick, are you sure your oil usage is not something simple like blow-by caused from over-filling the sump? Check and see if the oil level drops and then maintains itself at a stable level. A few years ago a well-known engine manufacturer miss-marked the oil level on their sumps and owners were experiencing sever oil blow-by. They remarked the sumps and the problem stopped.
If you think you have a ring seal problem you should run a compression and leak-down test. The Dealer should be able to do this for you.
With the flexible ring packs used today, ring seal should occur fairly quickly in the C6. The long break-in period recommended by the manual is for the various bearings, shafts and gears used in the engine, transmission and rear end.
The factory is supposed to apply enough wall loading to seat the rings properly during dyno testing (rings stop rotating and seat against the cylinder wall). This is one of the reasons they run the car under controlled loading before it is delivered to you. However, to be absolutely sure the rings are seated, you should load the engine carefully during the first 20 to 30 miles and NOT “baby” it (and it reads like you did it right from your post). Several owner surveys of high performance cars and motorcycles have shown that people who babied the engine during the first 100 miles had more engine problems later than those that ran it harder.
Little additional ring break-in is needed after the initial 30-mile run-in. If your engine is using oil after a few hundred miles (and not just blowing it out the breather system because you are over-filling the sump) there is a problem. In my experience, ring seal usually will not improve significantly with additional use after initial break-in. Good luck!
No offense, but ignore people who say to break it in hard. Read the owner's manual and follow the advice of the engineers who designed and built the car.
Regards,
Rick
