Rear View Mirror
Old May 19, 2005 | 08:09 PM
V Vette's Avatar
V Vette
Default Rear View Mirror
Any info on how to tighten up the rear view mirror? After all my wrenching and moving to install radar set up, the mirror now has slight movement and shakes slightly when driving.. Any help here? Thanks
Old May 20, 2005 | 07:19 PM
GGWOODY's Avatar
GGWOODY
From: Buena Park, CA I seem to have left my electrolytes with your daughter
V-
It shakes because you are adding weight to the bottom of the mirror, and giving it more leverage. Mine does the same thing, and I suppose evryone else's does too. But there is a solution, if you crank up the car and sit there in the garage staring at the wall, you can easily burn through a tank of gas and never see the mirror shimmy.
-G
Old May 20, 2005 | 08:09 PM
V Vette's Avatar
V Vette
Originally Posted by GGWOODY
V-
-G
G: get me dem picts of the blue bomber!!! Need to see wheels and da handles, da handles!
Old May 21, 2005 | 01:51 AM
quincy's Avatar
quincy
I put a small piece of black foam rubber in the mirror mount holding the radar unit and it eliminated most of the vibration
Old May 21, 2005 | 05:42 AM
LS WON's Avatar
LS WON
Default Just replace the mirror with a Wink wide angle mirror remember those?
V-
-G
To Rear View Mirror
