More than a problem, it seldom works at all. Took del of my car a couple of weeks ago. Drove off the lot and the XM reception became intermittent. Like a loose antenna lead. Took it to the dealer the next day for a look see. They said it couldn't be an antenna and that I must leave it for a day. Dropped it off a couple of days later and was then told I needed a new radio. Took 48 hours to get a new one. Still did the same thing. Now the dealer tells me it needs a new antenna but Chevy doesn't have any in stock anywhere. It must come direct from the supplier and will take close to a week.
I have seen all sorts of posts about XM issues but not nothing close to this problem. Any thoughts or advice?
From: YOU SEE ... I'M NOT CRAZY ...I'M JUST AHEAD OF THE CURVE
St. Jude Donor '09-'10
Did they actually check all the fittings to the antenna? If this is your second radio and the problem is exactly the same as described ,,,, other than a faulty attenta itself, what the heck else could it be but a loose fitting (s)??
I agree with you. Called the dealer for another report. I must be the only one in the Country with this problem. Dealer diagnostics says it is the receiver. New receiver seems to improved performance but not to good enough levels. Dealer says "engineers" are telling them to replace the antenna. It will take "at least" 2 weeks because the part is not available through conventional channels. Maybe some one needs to go to the antenna parts bin in Bowling Green and pull it from the plant as it is not available anywhere else. If one of you GM plant guys read this, call Carl Asher at Gunn Chey in San Antonio and tell him you are sending him a part special. I would hate to be the only guy in history to envoke the lemon law for a faulty XM signal.
Update: The dealer says that it will take at least 2 weeks to get the new antenna in. Of course, they are only guessing as it is the final part to replace. The time to get it is just a guess also as there is none to be found through conventional channels. I think of antennas as being a cable and a receiving peice. Are they more complicated and technical nowadays? It just doesn't seem this complicated.
I'm pretty sure the XM antenna is active. In other words, it has an RF amplifier in it.
I may have posted this before, but likely not in this thread? The following comes from a very high source and you can trust what's being said. I received this on March 31, 2005
This is a condition that Denso (Radio
manufacture) is aware of. It has to do with the sequence the radio uses to
power up the radio. There are times when the radio gets powered up before
the antenna sees the antenna module so the static is there because the radio
can't locate the antenna. Switching the radio to AM and back to FM allows
the radio to attach to the signal and the static should be gone. Denso is
working on a file-fix that will allow dealers to reprogram the radio in
the dealerships. the repair should take about 10 minutes when it is
completed. I don't have an accurate timing on the fix but it should be in
120 days or less.
120 days or less.
Thanks for the reply. I had read something to the same affect on the C6 general discussion board. I have tried that but it did not correct the problem. This is only fuzzy sometimes. Most of the time it will go from normal to silent, wait 1 to 10 minutes and then blurt out crystal clear at the last volume setting. Then may operate normal for 5 to 10 minutes and do it again.
Gary, it's only a guess, but perhaps you're going in/out of a satellite reception area, and if so, the system is again losing contact with the antenna? 10 minutes seems like a long time if you're driving? I would be interested in knowing if you've talked with your dealer regarding the Denso file-fix, if it's now available, or when they think it might be available? Thank you as well, for your update.
I will be meeting with the Service Manager tomorrow. I will be bringing it up to him. I think their initial thought was that it did need the re-programming. I didnt ask at the time but will tomorrow. When I first took it in and told them that it was a loose antenna, they told me no, that it was something they had to fix in the programming. My build date was 5/2 so I suppose it should have been loaded with the correct update at the plant.
I still have the exact problem too. The xm shows "no signal" with no sound, i'll get sound that hisses in and out continuously, or see the song titles but no sound. No problems on AM or FM.
Keep hearing about a software fix that "silvercoupe" had done at his dealer.
Talked to a guy down the block from me and his is perfect so it is an equipment and not xm service problem i would suppose.
Keep us informed - looking forward to hearing from you after the new antenna install.
The dealer got in the new XM wart yesterday and installed it. My XM now works great. For those that have fading or hissing when not under a roof or overhead structure, you may need to have your antenna changed. They are not a common stock item and takes a while to get one.
That's exactly what mine does. I think it has Tourette's Syndrome. I'll have no reception for ten minutes, and then, without warning and scaring the crapola outta me, the XM comes back on for 30 seconds. One thing for sure, I'm going to determine the fix before I have the local dealer futz with it for two months.
I have the same exact problem. My XM radio works intermittently at best. Usually gets "no signal" Dropped it off at dealer today .. will keep you posted.
okay... got the car back. dealer said coax cable leading to antenna had high resistance. they ordered new antenna and cable and said "dont be surprised if its not here for another month"
they didn't do anything about the FM radio static i asked them to check..."couldnt reproduce speech"
My car is at the dealer right now for the same exact issue-intermittant signal reception. The radio had never seemed to work, but I couldn't part with the car long enough to have it checked out if you know what I mean.
The issue according to early reports is not the antenna, but a module that is near the tail lights. Hope this fix works and also hope that GM will extend my trial period for the XM. So far even ignoring the static and fadeouts, I'm not sold on this whole program.
