4.10 Gear
these (if you're unable to calculate them) is to take
your C6 to 50, 60, 70 mph and measure the rpm.
Then, since 4.10s are almost exactly 20% more gear
than 3.42, you can expect 20% more rpm in any
given gear. So, for example, if you're turning 1500
rpm in 6th at 50 mph, you'd now be turning 1800 rpm.
4.10s will get you the following speeds:
1st 41mph @ 6500 rpm
2nd 59mph @ 6500 rpm
3rd 85 mph @ 6500 rpm
4th 123 mph @ 6500 rpm
This means 2 shifts to hit 60 mph.
Pat
Pat
Thanks again
Anyone correct me if I'm off on this.
Thanks again
measured 50, 60, and 70mph on my Z51 6spd.
Stock, in 6th gear:
50mph - 1250 rpm
60mph - 1500 rpm
70mph - 1750 rpm
Increasing by 20% for a 4.1 rear gear would yield:
50mph - 1500 rpm
60mph - 1800 rpm
70mph - 2100 rpm
Pat
great website for all kind of math computations for cars. One page even shows your rpm for 2 different rearend ratios.
Could be wrong but i though i read this was a rough indicator of your gearing for the vette.
Joe
