C5 Vacuum Leak
Old May 23, 2005 | 06:47 PM
mcmoore's Avatar
mcmoore
Default C5 Vacuum Leak
I removed the PCM from my '99 vert to send to the Vette Doctor only to find 2 corroded & broken vacuum lines running from the vacuum tank and check valve behind the PCM. Any idea where these vacuum lines go to and how to access where they go to? Any help would be appreciated.
Thanks,
Mike
Old May 23, 2005 | 07:45 PM
Vette_DD's Avatar
Vette_DD
If it's for a C5, suggest you ask this in the C5 section.
Old May 23, 2005 | 09:10 PM
BoostedZ06's Avatar
BoostedZ06
Thanks,
Mike
This happened from the battery leaking acid.
The vaccum hose from back of intake ends up inside the wiriing loom, to a vaccum reserve tank which then goes inside by the BCM ( under passenger floor door) to a HVAC router to control the vents located on right side.
Old May 23, 2005 | 10:17 PM
The Garage Master's Avatar
The Garage Master
I agree you will probably get better results in the C5 section.
To C5 Vacuum Leak
