Halltech's C6 Stinger SSM--It Rocks
I did not do this dyno. A customer purchased the C6 Stinger and drove to a local dyno some 45 miles away, and paid $100 for the dyno sesssion. He simply compared the results with his first dyno the week before he installed our C6 Stinger SSM.
The beauty of his results are that no programming needed to be performed, and we installed the system in 5 minutes.
The dyno numbers were his results now ours. His dyno shows 15.5 RWHP gain at 6600 over stock.
The dyno actually is not the best tool for any C6 aftermarket part. We have gone from a low of 337 RWHP bone stock, to a high of 359 RWHP with our C6 Stinger, and our Stinger Program.
Our Stinger takes 5 minutes to install, with no cutting, no trimming, and fits in the stock location of the C6 where the filter belongs on this car. Call me and I'll explain why.
Jim Hall
The Stinger has 5 times more filtration surface area compared to stock.
5 minute Installation: http://www.corvettec5.com/C6_Stinger...structions.pdf
LG Motorsports just picked up 8 RWHP with our C6 Stinger SSM. They told me in an email that it was a very hot humid night, and they expect to see more on a better day.
Heat kills the C6 on the dyno, but the numbers are close to what we got on Jim Booth's car. 11.3 RWHP.
Don't forget, this is without programming, and installs in less than 5 minutes.
We'll have a video install soon.
He has moved things around a little and I'm proof it works. I actually think I lost a little when I put on the Magnaflows but didn't get a chance to Dyno before and after! They sure sound nice and I was happy before the Stinger, but now I'M SOLD! They are a great combination!
I'm sure if you check his site he will be posting later tonight! He had a bigger smile on his face than I did at the Dyno!
He is a great guy, and wasn't going to go ahead if he couldn't prove a good enough increase.
He has it now! I'm sure after they get on a few more C-6's they will be on back order.
Jim Booth
Corvette Accessories Unlimited
Basically is this something I have to worry about even when washing my car?
.Jim
.I drove through a rainstorm with the stock setup doing 50 mph for about 10 minutes, got home and checked out the engine compartment. Some water here and there, since it is not sealed from the incoming air.
Our system is just as safe as stock, in fact the filtration area is 253 sq. inches vs. 90 for stock (65 if you don't count the stainless mesh). 5 times the surface area vs. stock.
Jim
As you most likely saw we make almost all of the items on our site. Except for the relationship with Halltech and a few others like Sal Zaino we do not carry many other vendors’ items. We do have in stock the full line of Halltech items for the 97-04 C5 & C6. We realize it is hard to sell our inventory if the items that we inventory are not on our site, but that is our problem. We will do a complete revamp when we get our GM approval for our current C6 items which we expect in a few weeks.
I can tell you, as I did people at Bloomington where we had Jim's systems, the Halltech System is well worth the money. I want to state that I Paid for my system and paid for the Dyno's! I don't owe anything to Halltech but I am sold on their product. If you are close to Wisconsin, I would also recommend the program upgrade for the C6 Jim has put together!
You can call us at 262-783-4228 if you are interested!
Jim Booth
www.cau-llc.com
C6ers, mod away!
-Chris
Chris, read the original discussion when it occurred and it sure sounded like you diagnosed the problem to me!
How can I say that? I took the exact same C6 Stinger SSM system (different color) including the C6 MAF I had used, and installed it on an 03 Z06. Now if Chris was right, then the same outcome would occur.
I did program his car as well, as you can see by the straightline a/f ratio.
Here is the dyno and pictures:
The problem with the C6 is the ECM countermeasures which foil most attempts to do before and after dynos, due to heat generated cat overtemp protection fuel enrichment, and the timing tables jumping into the Low Octane tables on the dyno.
Positioning the MAF at the rear has its advantages, since we were able to see the benefit without programming Jim's car, and it turned into an easier installation, since we did not have to install the extra MAF wire harness. I have $1200 worth of MAF wire extentions if anyone is interested.
Lou Gigliotti is running our C6 Stinger SSM on his race car. I'm told they saw another 10 RWHP on their 488 RWHP C6 with our Stinger. They are a supporting vendor here and have C6 Stinger SSMs in stock.
Jim
Jim
Very long download time. Stock C6 uninstall and C6 Stinger SSM install video by Halltech.
