Alignment Specs for C6 ... Z51
Old May 28, 2005 | 10:26 AM
rbl's Avatar
rbl
Default Alignment Specs for C6 ... Z51
What should the four wheel alignment be set at for good street use and decent track use. Street use is more important.
Seems that the factory alignment is never quite on.
Old May 28, 2005 | 12:14 PM
elh0102's Avatar
elh0102
I have about 4K miles, and three track events on these alignment specs, and it has worked well for me:
Camber: -1.5 front, -1.2 rear
Toe: 1/16 total in front, 1/8 total in rear
caster: 7.5 deg.
This amount of negative camber might be a wear factor if you do strictly street driving. But track events will be the limiting wear factor for me, so it's not a concern. My tires are Michelin PS2, 265/35 front, 295/35 rear, all 18" Champion Motorsport wheels.
Old May 28, 2005 | 12:35 PM
C5stein's Avatar
0C5stein
Former Vendor
That suggestion seems to be pretty consistant with how we have been setting them, other that I don't like the way the rear feels with toe in and I will get unmercefully flamed if I suggest toe out in the rear, so we usually set the rear at Zero toe. BTW, On Toe I'm talking inches not degrees. Camber and Caster are in degrees.
However, If you are running run flat tires, then I would back off those Camber settings by 1/2 degree or you will prematurely kill your tire's inside shoulders. You could then consider putting in 1/2 degree more caster to help with front camber in turns.
Old May 28, 2005 | 02:15 PM
rbl's Avatar
rbl
Great info and thank you. Another member posted this really nich chart:
http://www.corvetteforum.net/c5/toom...6alignment.htm
Old May 28, 2005 | 06:16 PM
DryHeat's Avatar
DryHeat
wow - nice chart - thanks
To Alignment Specs for C6 ... Z51
