LG Headers & Smog
Old Jun 1, 2005 | 05:09 PM
tfenton's Avatar
tfenton
Default LG Headers & Smog
Have a c6 w/ Borla exhaust and have LG long tube headers on order (with cats). Does anyone know if I will run into smog issues down the road? If so, any suggestions for contingency planning?
Thanks!
Old Jun 1, 2005 | 05:38 PM
TommyV's Avatar
TommyV
St. Jude Donor '06-'07-'08-'09-'10-'11-'12, '16
Where do you live? In Calif. "most" smog stations will not look under your car or check for CARB certification numbers. If it passes the "sniff" test, you should be fine.
Old Jun 1, 2005 | 07:20 PM
yellow1's Avatar
yellow1
Default LG and Inspections
Spoke to the LG folks recently and they again assured me there should be no problem here in Texas. You might give them a call or email and ask them, they're quite helpful
Old Jun 1, 2005 | 07:48 PM
sallen619's Avatar
sallen619
The police will check for CARB #'s out here if the car sounds to loud.
Old Jun 2, 2005 | 03:43 PM
synthtk's Avatar
synthtk
Every smog station ive been to (north country primarily) will pop the hood and look for things. Maybe eastcounty smog spots are more shady
Old Jun 2, 2005 | 04:39 PM
jimman's Avatar
jimman
Had mine smogged to get my base sticker and they checked everything.
Old Jun 2, 2005 | 05:40 PM
redvetteC6's Avatar
redvetteC6
From: Huntington Beach Ca 1 out of 4 Americans are mentally unstable, so if 3 of your friends are OK . . . .
St. Jude Donor '05
Smog shops in TJ are really, really lax. Hell, you don't even have to bring the car in.
Old Jun 2, 2005 | 06:22 PM
TommyV's Avatar
TommyV
They look for obvious things like disconnected hoses and vale cover breathers. "If" they see your headers, they won't care.
Old Jun 3, 2005 | 02:12 AM
WhiteDiamond's Avatar
WhiteDiamond
St. Jude Donor '15
Is LGM putting the cats right after the collectors on the C6 or are they moving them to after the x-pipe? I know it doesn't really help the Cali guys, but it could mean a bit for those going to larger cams and still hoping to pass a sniffer(ie: cat closer to the exhaust manifold is better).
Old Jun 3, 2005 | 10:40 AM
crabman's Avatar
crabman
Their picture shows the cats bolted to the header flange.
To LG Headers & Smog
