C6 LS2 Dyno Tuning
But here goes-- the computer knows torque-- from knowing
the engine VE, size, rpm, Mass Air Flow ect. If it sees the
Torque exceeding the levels set by G.M. It will try to reduce
torque down to the acceptable levels set in the programming
Retarding timing is the first level-- Second Level is closing
the throttle (drive by wire)! and third shutting down cylinders
via injector control to yes 4 cylinders if necessary- Later
we will have DOD Displacement on Demand (shutting down the
oil feed to the hydraulic lifter) that can be utilized for torque management. I can only speculate on the module from Cartek
but i beleive you could reduce the MAF air output signal- in
return the computer would not see full load and torque output
in return a leaner mixture more timing and the computer not seeing full load and not trying to control what it does not see
I do not know where the cartek module connects too Iam
only speculating how this type of device could work!
program look like this--
You select the gear 1st-6th- In that gear there is an rpm scale
500--600--700--800--900-1200--1500-2000-3000
85 89 104 111 126 126 185 244 281 ft lbs
this is a stock scale of maximum allowed torque output!
these values can be raised to any number of torque!
There are also torque limit values on the axle front and rear
Driveshaft Torque limit and Trans Torque Limit - I wish
I could post my laptop screen but anyone is more than welcome
to stop by the shop and i will show them Ls2 edit and all its glory
The Vette Doctors tuned my Z51 A4 today with LS2 Edit. In addition to advancing timing 5 degrees, changing fan kick-on, etc. they changed torque management parameters. We didn't dyno it, because auto trans parameters can not be changed yet. These C6's are a whole different ballgame than the C5's!
very good observation. Again my sources, from GM say the only Torque management is for the A4's torque converter. .
) views that mods claims are Now to be fair, LT1LS1, we're still waiting on before and after numbers
last week has several torque management features-- I lean the
mixture to 12.8 at peak torque and add a few degrees of timing
and the power jumps 15-20 Hp. I will say this ,- small changes
in the PE tables like 1-2 percent makes big changes in the
air/fuel ratio. The MAf Calibration is 5% bigger(richer) than
a Ls1 ZO6. I have found that recalibrating the MAf in the
High flow tables leans the fuel in the upper air flow ranges
and then I fine tune the PE table- Descreening the MAf is ok
as long as you get the long term fuel trims 0 to -5%. The
MAf sensor and airflow is very critical on the LS2 or should I say sensitive. I had an Ls2 Gto loose 20 Hp from installing a
New Era CAI. Then we added KOOKs Headers and lost another
23HP! I got the tune back in order- (Maf calibration mainly)
and got it all back +20HP. The a/f mix on the baseline-
customer installed the CAI was 8.5:1 (RICH) after the headers
it was 8.0:1 PIG RICH-. We tuned to 12.6- 13.0 and gained
almost 65 HP! 293HP to 358HP! My point is "Tuning is Everything" You can add hardware and go backwards without
getting the tune happy!
Thanks for the insight. As I've been saying (preaching actually), these things work as a system, with each mod affecting tune. Plan your mods as a package, and tune FOR that complete package - then you'll get the HP at the wheels, that everyone is looking for. Putting a Halltech/Honker/Whatever and expecting 15HP is ludicrious. Doing intake and exhaust mods, and then tuning for the resultant trim/flow, will give the results we're all looking for.
I played the same game for years with my Harleys. Get the heads done, the intake/carb aren't flowing enough. Put a new intake and carb on, the exhaust has to be retuned.
Do it all in one shot, and tune afterwards -> and just be done with it. The constant march of mod after mod can drive you nuts (and break the bank)...
Regards,
Rick
MTI, CARTEK, and Lingenfelter to name a few are all offering several different approaches to tune the C6, and who REALLY knows what works, as they are all in it for the bottom line.................to make a living. I would just like to have someone who REALLY knows what they are doing....................do it!
I think its a bit early in the game to know this, and don't even mention the subject of torque management again................GOD.........we do not know if it even EXISTS!
I have been a CF member for quite a while, as you know, and have had my ears "pinned back" too many times to admit. Yeah, I have been wrong, sometimes DEAD wrong, but life goes on. I would never intentionally disrepect ANY vendor and I know you know it.
BTW, I have been reading your posts for years on your "bone" stock Z06, running in the 11's..............trying to dupilcate the times with the last 3 Z06's I have owned, hitting a 12.2 with an intake only........your drag racing tips were and still are a tough act to follow.
BTW, after visiting their website, and checking their upcomming dyno days, they are still showing availability dates in AUGUST 2004...............a bit more credibility to their business would be in order also if they weren't 10 MONTHS behind in their website updates..............and after looking at the total website, I hire a new webmaster if I were them (him).......................
somethings are more important" and some wonder why tuners stay off the forum just trying to help others with info-
I have 25 years of experience in engine mangement system and have trained thousands of techs not to mention since 97 on the Ls1 and genIII family and theni let some __________ I'll stop i forgot I have no credibiltiy
