Normal Oil Temps?
What "should" the normal operating temps for oil be?
I find mine running between 219 & 225 for the most part (city/hwy driving in Ft. Lauderdale, Fl. - 85-95* ambient temps, 85% humidity or better). Coolant temps range between 195 & 205.
Should the Z51 Oil Cooler reduce these temps (or would they actually be HIGHER without the cooler)?
Are these temps to be expected in this type of ambient temperature?
Rick
Rick
Engines run better with oil in the 220-230dF range than with oil in the 180dF range (where better means longer life, more power, lower emissions).
Rick
