23lbs for calipers
Here is info from a past post
Brake Caliper Guide Pin Bolt 23 lb ft
Front Brake Caliper Mounting Bracket Bolt 125 lb ft
Rear Brake Caliper Mounting Bracket Bolt 125 lb ft
Brake Caliper Bleed Screw 106 lb in
Brake Caliper Inlet Fitting Bolt 33 lb ft
