Here is why your hatch button quits (pics)
Listed below is why the switch most likely fails and how you can fix the one you have if you want to save 2 trips to the dealer and are handy.
The switch is located just above the rear license plate and is accessed by removing the passenger side tail light closer to the emblem. The tail light simply removes with one screw (T 15 torx head).
Test
(If you want to test (have your FOB with you) to see if this will fix your non working button. Reach in and remove the harness (pull back retainer towards the rear and lift out harness) from the switch and press it back in. If the hatch opens when you reconnect the harness the switch is stuck in and the procedure below should correct it, if it does not open the hatch you have other issues. The button is a momentary contact switch)
With the harness removed, press the two clips in the picture and the switch drops down.
Remove the rubber cap from the switch by just pealing it back with your fingers. I found dust and sand in mine.
Attach a strong tape (electrical, duct or masking tape) to the button head only and pull out the button. Looking up inside you will see a rubber button that contains the contacts. There is no need to remove this since it’s the button that was stuck on mine most likely due to dust / dirt and water. Clean it well using a small paint brush and reassemble. I would not use any oils or grease since this will attract more dirt. Since the switch has no return spring it relies on the rubber inside button returning the removable button and any dirt offers enough resistance to make the button stick.
I ordered a replacement but could have just cleaned it and would have been fine.
I thought that maybe this switch problem wouldn't hit me but after looking at the photos of how it's assembled I'm certain it's just a matter of time. Thanks for the photos and tutorial, I think I'll pull it out now and clean/seal it before I have to.
I have read that the new switches are sealed better. Does anyone know if this is the case?
Its amazing that people on this site seem to be smarter then the guys the dealership have.PipeDreams,
Excellent info!! I am impressed with your ability to disassemble this thing.
James
