I did a search but couldn't find anything, but could have sworn I have read about this somewhere. I experienced the DBS a couple of days ago and now the windows won't index after I close the doors. Is there a re-learning process for this or is it a "dealer only fix"?
See Manual...there is a process after a power disconnect.
Originally Posted by clem zahrobsky:
"to fix the window push the button down and hold for 5 seconds and then pull it up and hold for 5 seconds"
It's in the FAQ section as well as your owner's manual, although you might need the help of the FAQ section to help you find it there.
I think Clem is right about this working, but I don't think you'll find it in the manual. The manual actually says to RAISE the window and hold for an extra 3 seconds, then hold for 3 seconds again.
I guess Clem's method is getting to be one of those "internet legends" that may or may not work.
I think Crabman is right about this working, but I don't think you'll find it in the manual. The manual actually says to RAISE the window and hold for an extra 3 seconds, then hold for 3 seconds again.
I guess Crabman's method is getting to be one of those "internet legends" that may or may not work.
this is the correct method; i tried it and it does work!
Stan knows his stuff. Before he went into the Maple Syrup business he was a Window Index Engineer for BMW
One more remark like that, Taylor, and I reveal your background as Hooter's only male waiter. I have pictures of you in your Hooter's tank top, so be careful.
