Auto trans leak
Old Jul 5, 2005 | 08:21 AM
winstonc's Avatar
winstonc
Default Auto trans leak
I was at Watkins Glen yesterday with my automatic C6 Z51 for some track time. Transmission kept overheating and was leaking fluid. What's the deal? How do I check the level in the transmission without going to a dealer?
I saw 1.2g a couple times though the uphill. Stock tires with 1.5 of negative camber. G meter must be wrong?
Thanks.
Old Jul 5, 2005 | 11:00 AM
LS1LT1's Avatar
LS1LT1
Automatics and hard road racing generally don't get along too well...you might need to get a bigger add on trans cooler to run in line with the stock Z51 cooler.
Old Jul 5, 2005 | 11:31 AM
winstonc's Avatar
winstonc
I know, I tryed it with a Auto C4 several years ago. Didn't have a problem with the tranny.
If I add an addition cooler how do I check the fluid level?
Back to my question. Do I really have to go to a dealer like the owners manual says.
Thanks.
Old Jul 5, 2005 | 11:37 AM
LS1LT1's Avatar
LS1LT1
No need to go to the dealer, there is a drain/fill plug on the side of the trans (gotta jack up the car quite a bit to get to it) and if you unscrew it some fluid should leak out...if not then it might be a bit low and you should refill it (using a pump of some sort). I'm assuming that the leak you're experiencing isn't coming from that bolt though.
Old Jul 5, 2005 | 11:44 AM
winstonc's Avatar
winstonc
Do I check it with the car running?
If I jack the car the tranny will not be level. Have to use a lift.
I drove 300 miles after I left the track and no leaks. Hope it was just a vent. I can't beleive that the tranny is totally sealed, since liquid expands when it gets hot.
Old Jul 5, 2005 | 02:56 PM
winstonc's Avatar
winstonc
Ordered the Helm service manual.
To Auto trans leak
