Nitrous Window Switch Help
Old Jul 19, 2005 | 01:25 PM
FLC6's Avatar
FLC6
Default Nitrous Window Switch Help
On an 05 C6 Auto:
Which wires on the ecu to tap into for the window switch?
Also, is it easy to install the fuel pressure switch?
Old Jul 19, 2005 | 01:59 PM
thorkonan's Avatar
thorkonan
At the SoCal C6 round up a guy had his nitrious switch wired to his hazard button. The install on his system was extremely clean done by WCC
Old Jul 19, 2005 | 03:19 PM
FLC6's Avatar
FLC6
Sounds great.
Too bad I am in South Florida
Old Jul 19, 2005 | 03:28 PM
U2bassAce's Avatar
U2bassAce
St. Jude Donor '06
Old Jul 19, 2005 | 03:38 PM
SpinMonster's Avatar
SpinMonster
White wire: pin #48 on the blue pcm connector. Be carefull of what you use to cut the bundle of wires open with....go slow and it will work. I tapped the window switch and the shift light at that spot. Set both for 4 cylinder operation.
Remember that the window switch provides a negative for the output not positive so the relay it drives should have the positive at it already and then the window switch will give the ground.
PM if you still have an issue. Also the pills are just resistors and you can approximate any value for the pills by the following:
rpm +1000= resistor value. Not so accurate in the upper rpm's but close enough to fool with....$1 for a bunch of them until you get it right
Old Jul 19, 2005 | 03:41 PM
FLC6's Avatar
FLC6
I bought the BMN WIndow Switch with 1st Gear Lockout.
It does not use pills. It is a dial.
Thanks for the info. Why would I want to set it to 4 cylinder op?
What shot do you have in your C6? Dry or wet?
Thanks!
Old Jul 19, 2005 | 03:42 PM
SpinMonster
The fuel pressure switch is easy but the calibration is a little tough if you get the cheaper nos one (you need to adjust it with an air pressure source for a pressure value under the GM fuel pressure level). It goes on the fuel rail with a fitting and it is wired in series with the relay from the window switch. Don't have it interupt the solenoid's power.
Old Jul 19, 2005 | 03:46 PM
SpinMonster
It is dry for now -C6: 80 shot- but I will switch to wet after I change the manifold.
C5 is wet progressive 125 shot.
You use the 4cyl operation mode because the tach signal at that wire feeds each of the coil pack sets separately. 4 coils, hence 4 cylinder.
Both my cars are juiced so its from experience I speak.
Old Jul 19, 2005 | 03:51 PM
FLC6's Avatar
FLC6
SO I take it you have the NOS dry kit as well.
What FPS switch are you using?
Old Jul 19, 2005 | 03:52 PM
SpinMonster
Nitrous express for my kit
Old Jul 19, 2005 | 03:55 PM
FLC6's Avatar
FLC6
Where did you mount your bottle? Can I mount mine sideways so I can still fit my roof?
Thanks for all your help!
Do you have any pictures of your setup
Old Jul 19, 2005 | 04:04 PM
thorkonan's Avatar
thorkonan
HERE IS THE SET UP FROM THE SOCAL ROUND UP, NOTICE THE GAUGE PLACEMENT
Old Jul 20, 2005 | 12:53 AM
SpinMonster
That is one nice set-up!!
I dont have any pics but the bottle fits in there with the roof panel. Just remember the bottle must be tilted and the correct orientation for the pick-up in the bottle.
To Nitrous Window Switch Help
