My C6 is unable to start. It just cranks and cranks. It's at a small dealership now in Durango Co where they do not have a Corvette mechanic. Has anyone else had this problem? If so, what was the fix.
hey, jazz, there was a thread on the forum here recently about one that would intermittently not start. it turned out to be the connector that went to the fuel pump or relay that had backed out of the plug just slightly. it was a real bear to find, but this dealer tech hung in and found it. it may be in the faq section. hope this helps, cranky
All gas engines need compression, fuel, and spark to run. If one is missing, it won't start. Now it isn't difficult to check for spark, and hardly more difficult to check for fuel. In the rare event of loss of compression, it isn't hard to test for that either. *Any* auto mechanic worthy of the name should know how to do these simple tests. Once he knows what's missing, it is merely a matter of systematically tracing back through that system to find the failure point. Basic engine repair 101, works for a lowly Briggs & Stratton lawn mower engine, and works for a LS2 powered Corvette too. It sounds like the "mechanics" working on your car don't qualify to work on a lawn mower.
As cranky says, a likely culprit is loss of fuel pressure due to an electrical fault in the fuel pump circuit. Some people have had this problem, and it turned out to be a connector not fully seated in the fuel pump circuit. That's not a guarantee that this is your problem, but other than the precise locations of the parts, there's nothing really different about the circuits and systems of a Corvette than any other Chevrolet of recent vintage. A mechanic competent to work on any other Chevy shouldn't find it difficult to work on this one.
I'm not sure if this is the same problem. I had my FSU replaced like so many others have had. So the fuel gauge works fine now. But ever since, when I start the car, it cranks for awhile and doesn't start. After a couple of seconds, I hit stop and try it again and it always works. This only occurs when I leave the car off for more than 10 minutes or so. Under 10 minutes, she'll start up just fine. Dealer looked at it and said they needed to replace the transfer fuel line between the two tanks. Part just came in and I'm taking the car in later this week to have it replaced. I'm crossing my fingers and hope this works.
This may be referring to me as that is exactly what occurred---took them almost 2 days to diagnose it and seconds to plug it back in and away I went.
Just received a call from the dealership and they found a loose ground wire to the fuel pump. They say car runs fine now.
This is now the fourth case of this happening that I remember here. In each case that I've seen posted, it always turned out to be a loose wire to the fuel pump or fuel pump relay. I wonder if it's always the same wire? Does anyone know where this wire/connector is? If so, it'd be great to add it to the FAQ if it's easy enough to get to and check for yourself.
