Max boost on C6, what do you think?
Old Jul 26, 2005 | 04:20 AM
Skunkworks's Avatar
Skunkworks
Default Max boost on C6, what do you think?
As title says, what would you think max boost would be on stock CR (10.9:1) cast pistons?
This is two parts – with and without methanol.
Then what kind of HP would you expect?
Old Jul 26, 2005 | 09:31 AM
brianw21's Avatar
brianw21
Well with the A&A kit and a LS1 (10.1 : 1) I run 9lbs all day long with no issues (523rwhp, no headers, stock engine).
So with the C6 you are seeing a pretty big jump in compression ratio.
What we do know is what the effective compression ratio for the LS1 with the A&A = (( 9 / 14.7 ) + 1 * 10.1 ) = 16.28
to get to this "reasonable level in a c6:
(( X / 14.7) + 1 * 10.9 ) = 16.28
X = 7lbs
If you go by the "SAFE" ATI numbers with higher intake temps:
LS1 = ((7/14.7) + 1 * 10.1 ) = 14.9
LS2 = ((X/14.7) + 1 * 10.9 ) = 14.9
X = 5.3 lbs
The LS6 was 10.5:1 and handled 7lbs on the A&A kit just fine. The ATI kit was 5-6.
Old Jul 26, 2005 | 11:25 AM
dshaner1's Avatar
dshaner1
I'd say 6 on pump gas, and 7 or 8 with meth.
Old Jul 26, 2005 | 11:36 AM
Fasterproms's Avatar
0Fasterproms
Former Vendor
9psi on pump gas will work but the candle that burns the brightest burns out the fastest.
I think 11-12psi on methanol is doable and or on race gas.
We have done 10psi on a stk bottom 10.5 a few times and they have stuck together.
Jeremy
Old Jul 26, 2005 | 01:02 PM
dshaner1's Avatar
dshaner1
Jeremy
Do you think 9psi on meth would be considered safe? I do have an extra Snow performance kit laying around
Old Jul 28, 2005 | 01:40 PM
Skunkworks's Avatar
Skunkworks
Thanks, for your input!
Mike
Old Jul 28, 2005 | 01:41 PM
Skunkworks's Avatar
Skunkworks
Mike
To Max boost on C6, what do you think?
