Installed the B&M SS..few observations>>>
Removing the center console is fairly straight forward, but found disconnecting the 6 wiring connectors somewhat tedious. Reinstalling.. piece of cake.
Found my first production flaw on the car...whoever installed the gear shift **** cross threaded the retaining torx screw...was a PITA to remove this one little screw...had to destroy it to get it out..no big deal since you do not reuse. And if this is the only production flaw on the car this is great...
Found the B&M directions a bit lacking...they do not show all the details of the OEM configuration in the center console area and the removal of the old bushings and installing new ones on the shifter base needs more detail. Found two errors...on my C6 the torx screw holding retaining the gear shift **** was a Torx T25 not T20 as indicated in the instructions...also new bolts that replace the OEM bolts that hold down the shifter are 7/16" not 3/8" as instructs note.
I would preferred to see torque specs for the various nuts and bolts...did by feel but since there is aluminum involved always like torqueing by the numbers not by feel.
And finally the OEM **** does NOT fit the B&M shifter without a bit of modification to the B&M shifter shaft...this was reported earlier by SickRick
Now to a few pics>>>
OEM shifter compared to the B&M shifter
And... here is a close up of the shafts so you can see the difference between the OEM and B&M... I did not knotch the shaft like the OEM shaft has but rather just created a flatted area
The mod to the shifter was very easy...just ground a flat area on shaft on the opposite side where the shaft slot is located>>>
Here is another view of the flatten area...I wrapped the entire shifter in painters take just to protect it from any grit etc from the grinding process (which took a total of 5 minutes to do...make sure you let the shaft cool before placing **** on it (thanks again SickRick)
Here is the B&M shifter installed (BTW since I had the console removed I went ahead and added some 'heat tape' in the area where the cup holder is located (the silver looking tape to the right of the shifter)
Here is a the thick insulating pad reinstalled (this item is not shown in the B&M instructs)>>>
I do not want to suggest this was a tough install...just a few minor hiccups at best. The B&M shifter is a fine piece...nicely machined. The shifter now imparts not only a shorter throw but a much more precise feel. I like it...
Michael
I left the stock bushings in, as the replacement ones are a little harder, and the car is brand new, so the original ones aren't "shot out" yet. The harder bushings will tend to impart more transmission of vibration to the shifter, so I went with the original ones...
Rick
stlthxlr8r...you may use any of my posts as you wish...I post for information and use...
Michael
Michael
Rick
Rick
Michael
It would probably be LESS ergonomic, if it was located further back - plus you'd be pushing UP instead of forward.
Rick
Rick
Don't think so. The hole in the **** is larger then the diameter of the shifter. You could probably put a threaded insert in the ****, but unless you use a setscrew to secure it, it'll likely turn. The shifter-shaft mod allows the stock **** to be used without mod'ing IT, but for those weak-@-heart, I'd advise calling B&M and seeing what they have in the works to resolve this issue.
Rick
Rick
Michael
