I've got a DSOM C6 Coupe with the Quad Oval Tip Bullets on there. I wanna add the B&B X-Pipe next week. Am I expecting the car to be louder with less resonance? Also, I noticed the B&B Long Tubes have no cats. Will I pass a smog test if I slap those on? If not, what can I do where I keep my cats but get some long tubes on there? Or should I just weld the stock cats onto a short tube setup (can you even do that)? Thanks for the info!
ok im a vette exhaust noob...are the cats on the x-pipe or at the end of the headers? *sheepish look*
The cats are on the "down slope" below the stock manifolds. The X-Pipes do not have cats in line with them. Any long tube headers will eliminate the space where the cats are from the factory. So, if you want cats and headers, they must somehow be incorporated into the X pipe. As someone said, B&B makes an X pipe set up this way. Or, you can have one welded into an X pipe later.
I would call Mike at B&B and discuss your options with him. He is very knowledgable on this topic. The "Boss" (Billy Boat) owns a C6 that is one of their test vehicles.
