Has anyone seen the performance stats on the new to be released Halltech cold air (the one that mounts in the grille)? I was wondering if it adds any HP
thats what were all waiting for. I already ordered one yet it sounds like its to cool the engine bay ( which makes some power ) over forcing more air to the filter not sure how its gonna work out but I figured I order it anyways.
I doubt that youll see much gain on a dyno,it will be more from feel at higher speeds.Im sure its good for a tenth in the quarter without even seeing it you.Ram air systems work well on all cars.I look forward to getting one as well.Hopefully install wont be to tricky.
The idea is not to force/ram air into the system, but to bring cooler, ambient air into the engine compartment/air intake area. It's the only design thus far, that will be resistant to sucking water into the motor (unless you submarine the entire front end, at least).
You won't see this potential gain in power on a dyno. You will see it on the road @ speed, when air is actually moving into the intake.
From: Prepare yourself, for a pride obliterating bich smack. Fairfax, VA
St. Jude Donor '06-'07-'08
SEC > BCS 4 St. Judes '09
Originally Posted by Jim Hall
All CAI units ship tomorrow and Wednesday.
i would like to order mine...where? are you doing anything with an attractive design that would be a plus in shows? the callaway sure is pretty. colored carbon fiber
the callaway sure is pretty. colored carbon fiber.
Actually, the Callaway Honkers are not carbon fiber, they are made of cross-linked polyethylene.
Better for this application: optimum rigidity/flexibility, withstands chemical and temperature environment, consistency/repeatability of finished shape, etc.
Good choice of material. Halltech has been using crosslinked polyethylene for 6 years now on all our intakes.
Rick
This is so true, and to add to the picture, not only does cooling make the air more dense, it displaces water vapor molecules, and replaces them with oxygen molecules, which contribute greatly to combustion, and therefore add power. Pretty much a win-win situation....
Reason: Context..
