This might disable "shutdown in reverse" requirement
Old Aug 15, 2005 | 03:14 PM
  #41
AMGPilot's Avatar
AMGPilot
mikeyc6,
Good idea and I hope you can develop the bypass for those people that want to disable it or at least create a "DIY / How To" so others can disable it if they wish
Old Aug 15, 2005 | 03:16 PM
  #42
VET4LES's Avatar
VET4LES
Originally Posted by 6spdC6
Without loosing my temper< I will answer this! As a long time car guy and Vette owner it would be nice to just jump in the car and start it up.
That is after doing a pilot to copilot shut down the ride before!!!!!
Example pulling car in garage, then engaging reverse. Then backing up a bit to double check then pulling on e brake then hitting the off button then listening to hear column lock then trying to move steering wheel. Taking cell phone and garage door remote out of car shutting door and waiting to see start light and other lights fade out. Then checking to see if red blinker light comes on
Then if I’m lucky the car will start next time, if not get out jumper cables and drive to dealer
Then posting all sorts of information, and reading everything I can to try to figure outs what wrong with my $60,000 car
The worst is then getting on line to answer a stupid question like “Why the F' is this an issue?
Old Aug 15, 2005 | 03:24 PM
  #43
mikeyc6's Avatar
mikeyc6
I've had DBS once with the car in reverse, but my initial start of this thread wasn't to address DBS. It was to address the need to shut down in reverse so that if/when your car must be driven or shut down by another person like a valet, friend, family member, ignorant service tech, etc. the battery won't go dead. After thinking about it some more, one failsafe must be added to my initial proposal. If done as I proposed and the engine were accidentally turned off while driving, the column lock would engage while the car is moving. Indeed I think that's the reason that the shutdown-in-reverse exists to begin with, so you'd probably have to disable column lock to make my proposal work.
And Stan... just give it more time. I was like you a couple of months ago. I remember you got your car a couple of months after I did so I had my car about as long as you've had yours now when my first (and so far only) DBS hit. Before my first DBS, I was like you, I figured it was quite rare and that only some cars had the problem. I too park mine for a month or more at a time even in the dead of winter and never had a problem. I always back into the garage, never hear a peep from the warning when you don't get it in reverse, and double checked mine after the DBS... it was still in reverse. My "it only happens to a few cars" idea was shattered one day when my battery was drained down to 2.4 volts after sitting only a few days. It'll happen to you. Have confidence. It just takes time.
Mike
Old Aug 15, 2005 | 04:12 PM
  #44
StanNH's Avatar
StanNH
Mike
Well, Mike, that's reassuring...not. So far my car has been remarkably free of most of the problems being reported. Still, I am concerned about these issues and the possibility that I can be hit with one or more of them at any time. That's why I had the DEW installed as a preventative measure...no problem, but I'd rather err on the side of caution. If GM does come up with a retroactive shutdown fix, I can guarantee you that I'll be on the phone with my dealer to have it done. Like the crank pulley bolt problem, my concern here is that GM doesn't seem to really have a handle on what's causing the problem.
In the meantime, I'll keep my fingers crossed and hope all stays golden until a TSB is issued.
Old Aug 15, 2005 | 04:54 PM
  #45
self1's Avatar
self1
To answer the original question, there are two reverse switches located on the transmission that are activated by a mechanical paw-like lever once the shift lever is moved to reverse.
THANK YOU!!!!!
Old Aug 15, 2005 | 07:27 PM
  #46
mikeyc6's Avatar
mikeyc6
I'll be in line right behind ya.
I don't plan to do the DEW for the crank bolt as I feel I'm over the hump for that one, but I know that the same thing I told you regarding the DBS could happen to me with the crank bolt. As for DBS, I've run into that one so I guess my DBSaphobia is worse than my crankaphobia.
At least I have a PriorityStart installed so I know there is no possibility of my battery actually being dead and no possibility of me getting stranded because of it. Still, it would be quite annoying to be out with someone at a nice restaurant to come out and have to get in the car through the trunk and reactivate power with the cigarette lighter only to hear giggles and a remark like "and you paid how much for this car".
Mike
Old Aug 15, 2005 | 07:52 PM
  #47
Hoonose's Avatar
Hoonose
Mike
What do you mean "get in the car through the trunk"?
Don't tell me you're crawling in!?
Old Aug 15, 2005 | 08:01 PM
  #48
C6 Strangebob's Avatar
C6 Strangebob
Question: if you leave the car parked mainly in your garage, and you have Battery Tender Plus, do you also need a Priority Start unit?
Old Aug 15, 2005 | 08:40 PM
  #49
Hoonose's Avatar
Hoonose
Only problem might be on an overnight trip where you can't run the tender.
Old Aug 15, 2005 | 10:47 PM
  #50
Jbal's Avatar
Jbal
Interesting post. What I find most meaningful is about a week before I encountered the dreaded DBS, I went from the manual lock to the passive mode. This was at 5 mos of ownership, & about 2500mi. No problems before the reset to passive.
Thanks for the tip, & I'll go back to manual lock!
Old Aug 15, 2005 | 10:55 PM
  #51
Hoonose's Avatar
Hoonose
I've used passive lock with horn notification since day one, and no DBS at least in 6 months. Your situation could just be coincidental. Of course it can't hurt to change it though.
Old Aug 15, 2005 | 11:08 PM
  #52
Jbal's Avatar
Jbal
Hoonose;
Well, you're probably right-guess at this point I'm just grasping at straws. Well, I'll give it a shot, & see what happens. By the way, thanks much for all your posts on the DBS issue-you've been very helpful
Take Care.
Old Aug 15, 2005 | 11:59 PM
  #53
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
this happen to a friend on a C-5 as he did not have the horn signal till i set it up for him. that is when he found out what was causing his battery to go dead. the corvette keys were on a hook in his kitchen and when they were walking thru the kitchen the vibration would lock and unlock the doors and turn on the lights but they never knew it till the horn signal was set up. he just switched off the fob and no more dead battery
Old Aug 16, 2005 | 12:28 PM
  #54
carjon's Avatar
carjon
I think it is dumb, I should be able to put into whatever gear or not that I want. I'll bet a bunch of people start the car with the clutch down and then let up the clutch forgetting it is in reverse.
GM tried to provide 3 functions (running, accessory and off) with a 2 position switch so they had to have some other method. Too clever for their own good. If the statement in another message about this going away for 2006 then even the general realized how stupid this is.
I never(used) to leave my car in gear. The parking brake is sufficient (other than the hills of SF). The engine, clutch, trans. aren't built to be a brake and hold the car stopped, the brakes are.
Old Aug 16, 2005 | 03:42 PM
  #55
Vegas Sam's Avatar
Vegas Sam
I've never left a car in gear in the garage until now.
I hope someone can figure out a way around this.
Old Aug 16, 2005 | 08:51 PM
  #56
Yogivette's Avatar
Yogivette
For all the nay sayers. I admit you shouldnt have to put it in reverse to shut it down properly but you do.
IT IS NOT THE FIRST TIME FOR CHEVY like someone said. Its not even the first time for CORVETTE. The old c4s (Specifically my 86) Made you put the car in reverse before you could take the key out. Nothing new here its just now people are forgetting because there is no mechanical stop to it. The car allows you to not put it in reverse. That being said i dont mind, never had a dead battery with my c6.
Old Aug 17, 2005 | 10:23 AM
  #57
mikeyc6's Avatar
mikeyc6
No. By the time I get the trunk open to pull the manual door release, I sometimes feel like I might as well crawl through though because that's about the only thing I haven't done at that point. Getting the trunk open in a dark parking garage with the key requires basically standing on your head, feeling and looking for the hole, inserting and turning. Maybe I just need more practice hitting the hole. In my own garage, I back the car up close to the ATV, so getting to the trunk is a real pain.
Mike
