SAE correction question
Old Aug 15, 2005 | 11:17 AM
xstang's Avatar
xstang
Default SAE correction question
Anyone know what the SAE correction factor should be for 101 degrees at 35pct humidity for 550ft elevation. My dyno sheet read 1.01 SAE w/10pct humidity.
The low humidity that day was 35pct.
Old Aug 15, 2005 | 07:11 PM
haljensen's Avatar
haljensen
Barometric pressure is one of the factors most dynos use to get SAE corrected HP/TQ. Maybe the air pressure was high enough to offset the high temperature? (29.92 inches of Mercury seem to be the standard).
Old Aug 15, 2005 | 09:39 PM
xstang's Avatar
xstang
At the time of the dyno it was 29.9.... Any idea on the correction
Old Aug 15, 2005 | 11:49 PM
haljensen's Avatar
haljensen
Maybe the standard for humidity is 25% or 45% so SAE corrected the humidity by 10%?
Old Aug 16, 2005 | 01:16 AM
C_Williams@RPM's Avatar
0C_Williams@RPM
Former Vendor
According to this site you should have seen a 1.05 correction SAE Correction Calculator
To SAE correction question
