Grinding Noise
Old Aug 16, 2005 | 09:56 PM
Roc Con's Avatar
Roc Con
Default Grinding Noise
I have a Z-51 6 speed and have noticed a grinding noise when turning. It is loud and always present when I first start the car after sitting a while. It seems to diminish after the car is driven a little. I brought it to the dealer a few months ago and they told me it was a normal noise. I've had 5 new Vettes and have never heard this . I am bringing it back tomorrow for the service tech to look at again. Anybody else dealt with this issue?
Old Aug 16, 2005 | 10:24 PM
C5 then C6's Avatar
C5 then C6
I have a little grinding action when I turn hard to the right....but not a big deal. Never heard it when turning to the left. I guess it's just made for TMS....
Old Aug 16, 2005 | 10:41 PM
C6V3tt3's Avatar
C6V3tt3
I have a grinding noise when taking off in first gear, in my Z-51. What could it be?
Old Aug 17, 2005 | 12:27 AM
xlr8rvette's Avatar
xlr8rvette
From: Fayetteville Arkansas recently moved from Oakland Ca
St. Jude Donor '06
Had same thing at 12000 miles. Dealer changed differential fluid. Noise went away.
KEEP THE WAVE
Old Aug 17, 2005 | 10:12 PM
Roc Con's Avatar
Roc Con
Dealer changed the fluid and added an additive to the differential. Seems to have helped a bit. The tech told me that they have seen this as few times but presently have no other fix. He suggested that the tolerences are builtvery tight in the rear end and this may be why we are experiencing the noise.
Old Aug 17, 2005 | 10:38 PM
redhot6's Avatar
redhot6
I hear the same thing in mine on occasion. I thought it was a rear brake rubbing. ??
Old Aug 20, 2005 | 07:34 AM
Biv1
Guest
Posts: n/a
Default The answer
You are all being sold a bill of goods. It is a power steering and front end rack vibration noise that is NOT normal. Let me guess, it happens when you have the A/C on and you have your foot on the brakes and at a stand still and you turn the wheel? Or it happens when you have your foot on the brake and backing up and turn the wheel?
It is a MAJOR design failure of GM. They screwed up and do not want to step up to the plate. The few people that have it, the experience varies in degrees. Some it happens a few times. I can also say it was not there when you bought the car, correct. It started after 1000 miles, when the pump and car started to break in.
Very simple, when the car heats up the fluids expand and there is not enough back pressure or fluid when the power steering unit calls for it. There is DOCUMENT # PIC3109 that was issued on August 19, 2004. Right, before the car was released. The same mess they got into with the front license plate. 50 states in the Union and some require front license plates. So they knew about it before the car was released and did not disclose it.
GM States this is a normal characteristic. It is not. I would bring the car back and complain. The more people that do, it will cause them to re-engineer the power unit, rack and hose lines.
My car has it so severe that I am pending a Lemon Law hearing. Another person in another state had GM Techs agree to change the rack and steering pump. They refuse to even look at my car.
My dealer mechanic told me that GM Corporate is wrong on this one and he explained to them how bad my car is. The entire front end vibrates and shakes when I turn it. This is not normal? No I am not sensative to the front end. I am just another corvette owner that bought a lemon, because GM refuses to step up to the plate and fix it.
Even if I am not successful at the hearing, I win. This car will always be labeled that it had a lemon law hearing and GM will have to disclose it.
No one should be subjected to this treatment. All I asked is to have my car fixed. They do not want to spend the money to re-enginieer a major mistake. It will come out in the future that they had this problem and had to fix it. Because the more people that come forward on this issue and say it is NOT NORMAL, they will have to fix it, just like the Z51 brake pad issue which they say it is normal to hearing squeaking and squealing so loud that even with the radio on loud you can not hear anything else.
Another person I contacted in an another state had the same thing, the dealer changed the rack and power unit, which casued this condition to be reduced. I can not even get them to change anything. The lawyers from GM want to know what accidents my car had. The only accident is the GM Engineer that hit their head when they were designing the power steering pump and front end.
I know exactly what happened and I will make it my mission to tell everyone.
Old Aug 20, 2005 | 09:46 AM
Bumpstick's Avatar
Bumpstick
Thanks for the heads up.
Old Sep 9, 2005 | 07:30 PM
blahargoue's Avatar
blahargoue
7th Gear
Default Regarding Biv1's Answer:
I think we are talking about two different things. Mine was coming out of the rear differential, like most peoples' issue. I just got mine back from the dealer. He added the friction modifier and now, all is well.
Old Sep 9, 2005 | 08:25 PM
sallen619's Avatar
sallen619
The REAL answer...clutch plates in the rear diff. If you put your car on a lift, your probably leaking oil (even if you don't see it on the floor of your garage).
How do I know this...i've had the fluid replaced before..the noise will come back...there is a bulletin out on this. My car is in the shop as we speak getting the rear diff rebuilt...along with another C6 with the same problem at my dealership.
To Grinding Noise
