Installed skip shift eliminator from Mid America on C6. The check engine light comes on and the code is for the skip shift. Take the skip shift off, clear code and check engine light stays off.
Has anyone had similar problems when installing a skip shift on a C6 since it never triggered a code on my C5.
Should I try another vendor or is there no way to get around the check engine light coming on?
Faulty "eliminator". It has to have a resistor built into it that simulates the electrical resistance of the transmission solenoid...if the resistor is incorrect or missing, OR if you forego the "eliminator" and just unplug the harness, you get the code. Seek redress from MA or try another vendor.
