Another Leaky Rear-End
Old Aug 18, 2005 | 03:26 PM
Quick 06's Avatar
Quick 06
Default Another Leaky Rear-End
1300 miles on my C-6 Coupe and it's in the shop for a leaking o-ring on the differential casing (forward left side). It was terrible to see the rear of my car ripped apart to fix a XXXX o-ring. Had to drop left rear suspension and muffler to get to it. Dealer said that they've seen one or two others with near-same problem. It only showed a spot or two on my garage floor; however, when they got it on the lift you could see that it had probably been leaking since birth.
Thought it was worth a heads up to anyone that see's intermittent spots in their parking place.
Old Aug 19, 2005 | 07:48 AM
Blue Demon's Avatar
Blue Demon
From: And then it was said... "let there be blue Corvettes and yellow Camaros" Ft Worth Texas
Cruise-In IV Veteran
St. Jude Donor '09
This is just great. I had a total of 12 differential leaks on 4 different C5's so now I guess I'll have the same thing to look forward to on my C6.
